I'm trying to make a polyphonic synth with an Arduino UNO but I'm having trouble reading midi input. Anyone see any obvious mistakes?
I've tested with another sketch and the hardware works fine so that's not the issue.
The LED on pin 13 should be turning on and off with MIDI input but it doesn't in this sketch.
#include <MIDI.h>
#define samplingRate 62500
float midiNotes[] = {8.18, 8.66, 9.18, 9.72, 10.3, 10.91, 11.56, 12.25, 12.98, 13.75, 14.57, 15.43, 16.35, 17.32, 18.35, 19.45, 20.6, 21.83, 23.12, 24.5, 25.96, 27.5, 29.14, 30.87, 32.7, 34.65, 36.71, 38.89, 41.2, 43.65, 46.25, 49, 51.91, 55, 58.27, 61.74, 65.41, 69.3, 73.42, 77.78, 82.41, 87.31, 92.5, 98, 103.83, 110, 116.54, 123.47, 130.81, 138.59, 146.83, 155.56, 164.81, 174.61, 185, 196, 207.65, 220, 233.08, 246.94, 261.63, 277.18, 293.66, 311.13, 329.63, 349.23, 369.99, 392, 415.3, 440, 466.16, 493.88, 523.25, 554.37, 587.33, 622.25, 659.26, 698.46, 739.99, 783.99, 830.61, 880, 932.33, 987.77, 1046.5, 1108.73, 1174.66, 1244.51, 1318.51, 1396.91, 1479.98, 1567.98, 1661.22, 1760, 1864.66, 1975.53, 2093, 2217.46, 2349.32, 2489.02, 2637.02, 2793.83, 2959.96, 3135.96, 3322.44, 3520, 3729.31, 3951.07, 4186.01, 4434.92, 4698.64, 4978.03, 5274.04, 5587.65, 5919.91, 6271.93, 6644.88, 7040, 7458.62, 7902.13, 8372.02, 8869.84, 9397.27, 9956.06, 10548.08, 11175.3, 11839.82, 12543.85};
typedef struct Notes {
int onTime;
int offTime;
int hasBeenOn;
} Note;
Note getNoteTimes(float pitch, float dutyCycle){
float period = samplingRate/pitch;
Note finalNote = {round(dutyCycle*period), round((1-dutyCycle)*period), 0};
return finalNote;
volatile Note playingNotes[] = {getNoteTimes(261.6, 0.1), getNoteTimes(329.6, 0.1), getNoteTimes(392.0, 0.1)};
MIDI_CREATE_DEFAULT_INSTANCE();
void handleNoteOn(byte channel, byte pitch, byte velocity){
digitalWrite(13, HIGH);
void handleNoteOff(byte channel, byte pitch, byte velocity){
digitalWrite(13, LOW);
void setup(){
pinMode(9, OUTPUT);
pinMode(13, OUTPUT);
MIDI.setHandleNoteOn(handleNoteOn);
MIDI.setHandleNoteOff(handleNoteOff);
MIDI.begin(MIDI_CHANNEL_OMNI);
cli(); //stop interrupts
TCCR2A = 0; // set Timer/Counter Control Registers (TCCR2A/B) to 0
TCCR2B = 0;
OCR2A = 0; // = 16000000 / (freq*prescaler) - 1 (must be <256)
// turn on CTC mode
TCCR2A |= (1 << WGM21);
// Set CS01 and CS00 bits for 64 prescaler
TCCR2B |= (1 << CS20);
// enable timer compare interrupt
TIMSK2 |= (1 << OCIE2A);
sei(); //allow interrupts
void loop(){
MIDI.read();
ISR(TIMER2_COMPA_vect){
bool shouldPlay = false;
for(int i = 0; i<(sizeof(playingNotes)/sizeof(playingNotes[0])); i++){
playingNotes[i].hasBeenOn++;
if(playingNotes[i].hasBeenOn > playingNotes[i].onTime){
playingNotes[i].hasBeenOn = -playingNotes[i].offTime;
if(playingNotes[i].hasBeenOn >= 0){
shouldPlay = true;
if(shouldPlay){
PORTB |= 1 << 1;
}else{
PORTB &= ~(1 << 1);
