MIDI KEYBOARD
hello guys, i was building midi keyboard. i found you code here on forum
#include <Keypad.h>
const byte ROWS = 8; //eight rows
const byte COLS = 8; //eight columns
char hexaKeys[COLS][ROWS] = {
{‘A’, ‘B’, ‘C’, ‘D’, ‘E’, ‘F’, ‘G’, ‘H’},
{‘I’, ‘J’, ‘K’, ‘L’, ‘M’, ‘N’, ‘O’, ‘P’},
{‘Q’, ‘R’, ‘S’, ‘T’, ‘U’, ‘V’, ‘W’, ‘X’},
{‘Y’, ‘Z’, ‘0’, ‘1’, ‘2’, ‘3’, ‘4’, ‘5’},
{‘6’, ‘7’, ‘8’, ‘9’, ‘a’, ‘b’, ‘c’, ‘d’},
{‘e’, ‘f’, ‘g’, ‘h’, ‘i’, ‘j’, ‘k’, ‘l’},
{‘m’, ‘n’, ‘o’, ‘p’, ‘q’, ‘r’, ‘s’, ‘t’},
{‘u’, ‘v’, ‘w’, ‘x’, ‘y’, ‘z’, ‘!’, ‘@’}
byte colPins[ROWS] = {5, 6, 7, 8, 9, 10, 11, 12}; //connect to the row pinouts of the keypad
byte rowPins[COLS] = {A0, A1, A2, A3, A4, A5, A6, A7}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
char customKey = customKeypad.getKey();
if (customKey) {
Serial.println(customKey);
but i have 6 row and 8 cols: 6 in digital and 8 in analog,also i want to add release and MIDI USB code, i am trying to modify code but i can’t. please can you guys help me out. thanks in advance
You can start by modifying this
I did but it says error: too many initializers for 'char [6]' even if i delete last two rows, if i do wrong i'm just rookie sorry
Attache the error report. Use code tags. To be sure, attache the code,
#include <Keypad.h>
const byte ROWS = 6; //six rows
byte colPins[ROWS] = {5, 6, 7, 8, 9, 10}; //connect to the row pinouts of the keypad
if (customKey) {
this is the code i modified and error message is
Arduino: 1.8.10 (Mac OS X), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
sketch_jan17a:13:1: error: too many initializers for ‘char [6]’
sketch_jan17a:14:48: error: too many initializers for ‘byte [6] {aka unsigned char [6]}’
Multiple libraries were found for “Keypad.h”
Used: /Users/macbook/Documents/Arduino/libraries/Keypad
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
You works too fast.
Check this:
And, please, use code tags, up, to left inthis window.
Still the same error, too many initializers for 'char[6]'
What changes did You make reading my answer?
Code and error report, using code tags please.
i just copied your code as i said i don’t a word in programing, i can’t get service and can’t learn, cause it’s too hard for me. i am just musician and want build simple MIDI keyboard, when i started this project i didn’t know it could take this amount of time and also i didn’t want to bother someone. like you guys on forum.
#include <Keypad.h>
{'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H'},
{'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P'},
{'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X'},
{'Y', 'Z', '0', '1', '2', '3', '4', '5'},
{'6', '7', '8', '9', 'a', 'b', 'c', 'd'},
{'e', 'f', 'g', 'h', 'i', 'j', 'k', 'l'}
if (customKey) {
error message:Arduino: 1.8.10 (Mac OS X), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
exit status 1
Okey. Maybe You can find a coding experienced friend to help You. I will not read and penetrate Your entire code.
If You read my previous answer again You will see that You defined "ROWS" to contain 6 elements. Then You try to push 8 elements into that array sized for 6.
Yes you absolutely right, i can't understand any words. thank you, it's my fault i couldn't understand anything.
The business of coding is fun for a lot of people. They enjoy learning, correcting errors, until the projet works. Other members just want their stuff to work. I don't want to be rude, to be ruff, but either You pick up the work of learning some coding or You go to the "toy shop", buying ready equipment.
Myself I once spent a hole year, changing the code, rebuilding the hardware in order to make it work. Then, suddenly, I woke up in the middle of night and new, remembered a hardware signal I left out 3 years earlier.
