Midi Library Code - Beginner Question
my Sketch should connect up to 6 Buttons with 6 LEDs (actually 2 in use).
It is my first Sketch and i had some trouble to get to this point :slight_smile:
The Code is working, but if someone has ideas for change, im happy to implement it.
Question now:
  midiOut.sendControlChange(param1[val],velo1[val],channel1[val]);
You see i was able to make the variables in the brackets right.
I would like to change "sendControlChange" to a variable, so i can choose.
Is this possible?
Thanks in advance, Arduino is great :slight_smile:
EDIT: I updated the code once again, now 2 dimension for arrays, less code.
#include <MIDI.h>
#include <midi_Defs.h>
#include <midi_Message.h>
#include <midi_Namespace.h>
#include <midi_Settings.h>
int LEDPins[6] = {13, 12,9,8};                               // create Array of LED Pins according to Buttons, max 6
int ButtonPins[6] =  {10, 11,7,6,5,4};                          // create Array of Button Pins, max 6
bool ButtonStates[6] = {true, true};                   // create Array of Buttons States (true = on, false = off)
unsigned long startMillis[12];                       // create Array of Start Times for Buttons
unsigned long currentMillis[12];                    // create Array of Current Times for Buttons
int inputdebounce[6] = {10, 10, 10, 10, 10, 10};    // create Array of Input debounce Times, so every button can be debounced seperatly
int holdtime[6] = {250, 250, 250, 250, 250, 250};  // create Array of Input Hold Times, so every button can be set seperatly
const byte param[3][6] = {{14,81},                   // Variables for 3 on and 3 off control changes, called in functions buttonon and buttonoff
                          {19},
                          {31}};
const byte velo[3][6] = {{127,127},
                         {0},
                         {127}};
const byte channel[3][6] = {{2,2},
                            {2},
                            {2}};
const byte paramoff[3][6] = {{14,81},
                             {19,},
                             {31,}};
const byte velooff[3][6] = {{0,0},
                            {127},
                            {0}};
const byte channeloff[3][6] = {{2,2},
                               {2},
                               {2}};
MIDI_CREATE_DEFAULT_INSTANCE();   // create a MIDI object called midiOut
  for (int thisPin = 0; thisPin < (sizeof(LEDPins) / sizeof(LEDPins[0])); thisPin++) {      // Pin Modes for LED
    pinMode(LEDPins[thisPin], OUTPUT);
  for (int thisButton = 0; thisButton < (sizeof(ButtonPins) / sizeof(ButtonPins[0])); thisButton++) {     // Pin Modes for Buttons
    pinMode(ButtonPins[thisButton], INPUT);
  for ( int thisstartMillis = 0; thisstartMillis < (sizeof(startMillis) / sizeof(startMillis[0])); thisstartMillis++) {     // set Start Times for Buttons to current millis
    startMillis[thisstartMillis] = millis();
  Serial.begin(31250); // setup MIDI output
  for (int thisButton = 0; thisButton < (sizeof(ButtonPins) / sizeof(ButtonPins[0])); thisButton++) {     // for going through every element of ButtonPins[] and checking Input
    if (digitalRead (ButtonPins[thisButton]) == LOW && ButtonStates[thisButton] == true) {                // MIDI ON read, check button state Input and State per Button
      currentMillis[thisButton] = millis();                                                               //get the current millis per Button
      if (currentMillis[thisButton] - startMillis[thisButton] >= inputdebounce[thisButton]) {             //test whether the input debounce has elapsed
        buttonon(thisButton);        // function for MIDI Output, Opens switch case for every Button
        digitalWrite (LEDPins[thisButton], HIGH);                                                         // writes LED high, according to Button
        currentMillis[thisButton] = millis();                                                             // sets current timer to millis
        startMillis[thisButton] = currentMillis[thisButton];                                              // sets start millis to current millis
        startMillis[thisButton + 6] = currentMillis[thisButton];                                          // set start millis to current millis, used for button hold function
        ButtonStates[thisButton] = false  ;                                                               // sets button state
      else {
        startMillis[thisButton] = millis();                                                               // sets start millis to millis, to get debounce go again
    if (digitalRead (ButtonPins[thisButton]) == LOW && ButtonStates[thisButton] == false) {               // MIDI OFF, same if loop as above but inverted
        buttonoff(thisButton);
        digitalWrite (LEDPins[thisButton], LOW);
        ButtonStates[thisButton] = true;
      else {
    if (digitalRead (ButtonPins[thisButton]) == HIGH && ButtonStates[thisButton] == false ) {         // MIDI HOLD, depending on second timer block [thisButton +6]
      currentMillis[thisButton + 6] = millis();
      if ( currentMillis[thisButton + 6] - startMillis[thisButton + 6] >= holdtime[thisButton]) {
      else {
        startMillis[thisButton + 6] = millis();
void buttonon (int val) {     //midi function for button on control per button on click
      MIDI.sendControlChange(param[0][val],velo[0][val],channel[0][val]); // send a MIDI CC
      MIDI.sendControlChange(param[1][val],velo[1][val],channel[1][val]); // send a MIDI CC
      MIDI.sendControlChange(param[2][val],velo[2][val],channel[2][val]); // send a MIDI CC
void buttonoff (int val) {   //midi function for button off control per button on click
      MIDI.sendControlChange(paramoff[0][val],velooff[0][val],channeloff[0][val]); // send a MIDI CC
      MIDI.sendControlChange(paramoff[1][val],velooff[1][val],channeloff[1][val]); // send a MIDI CC
      MIDI.sendControlChange(paramoff[2][val],velooff[2][val],channeloff[2][val]); // send a MIDI CC
I recommend that you write a function that takes all the same arguments as MIDI.sendControlChange plus one to indicate which midi function you want to call.
void midiFunc(int function, int param, int velo, int channel)
    switch (function)
    case SendControl:
        MIDI.sendControlChange(param,velo,channel);
    case SendNote:
        MIDI.sendNote(param,velo,channel);
Simple and effektive, thank you :slight_smile:
I changed my Code according your input. Works right, i think.
is there any thing im doing wrong with my code? ideas? complains?
#include <MIDI.h>
                          {19},
                          {31}};
                         {0},
                         {127}};
                            {2},
                            {2}};
                             {19,},
                             {31,}};
                            {127},
                            {0}};
                               {2},
                               {2}};
const byte function[3][6] = {{4,4},
                             {4},
                             {4}};
        for (int i = 0; i < 3;i++){
          buttonon(function[i][thisButton], thisButton, i); // function for MIDI Output, Opens switch case for every Button   // function for MIDI Output, Opens switch case for every Button
      else {
          buttonoff(function[i][thisButton], thisButton, i);     // function for MIDI Output, Opens switch case for every Button
      else {
      else {
void buttonon (int function, int thisButton, int i) {     //midi function for button on control per button on click
    switch (function)
    case 4:
        MIDI.sendControlChange(param[i][thisButton],velo[i][thisButton],channel[i][thisButton]); // send a MIDI CC
    case 1:
        MIDI.sendNoteOn(param[i][thisButton],velo[i][thisButton],channel[i][thisButton]); // send a MIDI CC
    case 2:
        MIDI.sendNoteOff(param[i][thisButton],velo[i][thisButton],channel[i][thisButton]); // send a MIDI CC
    case 3:
void buttonoff (int function,int thisButton,int i) {
    switch (function)
    case 4:
        MIDI.sendControlChange(paramoff[i][thisButton],velooff[i][thisButton],channeloff[i][thisButton]); // send a MIDI CC
    case 1:
        MIDI.sendNoteOn(paramoff[i][thisButton],velooff[i][thisButton],channeloff[i][thisButton]); // send a MIDI CC
    case 2:
        MIDI.sendNoteOff(paramoff[i][thisButton],velooff[i][thisButton],channeloff[i][thisButton]); // send a MIDI CC
    case 3:
