i am using the "official" MIDI library and have a question, because i can't understand the documentation:
http://playground.arduino.cc/Main/MIDILibrary#.Uywgftyhhwo
Instead of the standard MIDI input port i'd like to use the second one on am Arduino Mega 2560.
May someone tell what to write instead of..
MIDI.begin(MIDI_CHANNEL_OMNI);
Thank you!
Greetz Chris
You need to edit the library header file. It is pretty clear when you read the file.
After downgrading to the MIDI library V.3.2 i found everything i had to find in the MIDI.h-file.
If i change
#define USE_SERIAL_PORT Serial // Change the number (to Serial1 for example)
to
#define USE_SERIAL_PORT Serial1 // Change the number (to Serial1 for example)
Serial0 does not work anymore, but Serial1 does not work too.
When i switch back to
Serial0 works perfect again.
May someone explain, what's going on there (Arduino Mega 2560)?
Greetz Chris
