hi there,
i have recently been messing around with midi program changes to switch on/off LEDS
just by using simple digital read and writes which is working fine.
However i wanted to expand the ouput pins and got hold of some shift registers to work with. I have looked at bits
of code where LEDs strobe up and down the 8bit LED layout.
Now i want to manually control the shift register bits according to the program change, just using 1 shift register for now.
I am getting a bit confused on how to control shift register bits on and off in contrast to the condition of the midi program change message.
I know digitalread and write can set pins high or low, but how do i control shiftregister bits high or low? because i saw an example where it uses code like setRegisterPin(0, HIGH);
yet is there a way of reading the condition of that setRegisterPin bit to switch it to low if it receives the same program change message?
kind of confusing to put down what i am trying to get help with as i havent used shiftregisters with arduino much.
thanks
