MIDI on RX1 and TX1 for Arduino MEGA does not work
I'm trying to use RX1/TX1 serial port for midi in and out, without success.
Actually, all midi data goes on TX0/RX0 pin, which is already used by USB.
Here is a simple example, which works fine when MIDI circuit is connected to TX0/RX0, but nothing happens when connected to TX1/RX1.
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
static const unsigned ledPin = 13;      // LED pin on Arduino
    pinMode(ledPin, OUTPUT);
    MIDI.begin();                      // Launch MIDI
        MIDI.sendNoteOn(42, 127, 1);    // Send a Note (pitch 42, velo 127 on channel 1)
        delay(1000);		            // Wait for a second
        MIDI.sendNoteOff(42, 0, 1);     // Stop the note
Is there function that set the Serial port to be used for MIDI? I tried including the following in the void setup() without success:
Serial1.begin();
Thanks for you help,
Lionel
Finally solved:
Replaced:
With:
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
Cheers,
Lionel
