Midi Ondes Martenot Code Error
Hi All,
I’m still trying to replicate Mitsushi Abe’s midi ondes martenot,
but i’m fairly new to coding and i am having trouble with his code, i get the following error message;
Midi_ondes_potential:56: error: ‘serial’ does not name a type
serial.write (byte (data1)); Serial.write (byte (data2)); void SendMIDI (char cmd, char data1, char data2)
Midi_ondes_potential:56: error: ‘Serial’ does not name a type
/Users/robertjedwards/Documents/Arduino/Midi_ondes_potential/Midi_ondes_potential.ino: In function ‘void SendMIDI(char, char, char)’:
Midi_ondes_potential:58: error: ‘serial’ was not declared in this scope
serial.write (byte
Midi_ondes_potential:62: error: expected primary-expression before ‘void’
void control () {
Midi_ondes_potential:83: error: ‘midiValue’ was not declared in this scope
MidiValue = sensorValue / 7.6; if (midiValue> 127) {midiValue = 127;} void volume () {
Midi_ondes_potential:83: error: a function-definition is not allowed here before ‘{’ token
Midi_ondes_potential:198: error: expected ‘}’ at end of input
exit status 1
Any help would be greatly appreciated :slight_smile:
Below is Mitsushi’s example code;
#include <MIDI.h>
#define SWITCH 7 // connect the micro switch to D7
#define PITCHADJUST 8 // connect the push switch to D8
int PITCHADJUST_RANGE = 0;
int PITCH_RANGE = 24;
#define PITCHINPUT 1 // connect the center pin of 10-turn potentiometer to A1
int SensorPin = 0; // Connect The Pressure Sensor To A0
int sensorValue;
int MidiValue = 0; // Volume Value
int Old_midiValue;
int Cc = 7; // Main Volume For MIDI Control Change
int bendPin = 2; // connect the potentiometer to A2
int bendValue;
int midibendValue = 0; // bend Value
int old_midibendValue;
int br = 58; // MIDI bendrange change (depends on user’s difinition)
int cutoffPin = 3; // connect the slide pot to A3
int cutoffValue;
int midicutoffValue = 0; // cutoff Value
int old_midicutoffValue;
int cu = 74; // MIDI cutoff change
int MidiCh = 1;
int Notecounter = 0; // Counter Used To Avoid Refrainig Note On
int val1 = 0;
int val2 = 0;
int Data3 = 0;
int MIDI_ROOT_NOTE = 60;
byte lowerBits; // Pitchbend value LSB
byte upperBits; // Pitchbend value MSB
int iCounter = 0; // Counter used to reduce the sample rate
byte noteOnToggle = HIGH; // Used to hold the state of the beam
float MIDIPITCHSCALE = 0.03785;
serial.write (byte
void control () {
val1 = digitalRead (SWITCH);
if (val1 == HIGH)
Notecounter = Notecounter Tasu 1;
if (Notecounter == 1)
SendMIDI (0X90, MIDI_ROOT_NOTE, 127); // Send The Root Note
// NOTE OFF
SendMIDI (0X80, MIDI_ROOT_NOTE , 127); // Silence the note
notecounter = 0; // Reset the counter
sensorValue = analogRead (sensorPin)
if (midiValue! = Old_midiValue)
SendMIDI (0xB0, cc, midiValue);
old_midiValue = midiValue;
} MidibendValue = bendValue / 8; if (midibendValue> 127) {midibendValue = 127; }
void bendrange () {
// this pot notice
mandatory
bendValue = }
if (midibendValue! = Old_midibendValue)
SendMIDI (0xB0, br, midibendValue);
old_midibendValue = midibendValue;
void cutoff () {
cutoffValue = analogRead (cutoffPin);
midicutoffValue = cutoffValue / 8;
if (midicutoffValue> 127) {midicutoffValue = 127;
if (midicutoffValue! = Old_midicutoffValue)
SendMIDI (0xB0, cu, midicutoffValue);
old_midicutoffValue = midicutoffValue;
ProcessAnalogValue void (Byte I)
// Get A Value For The GP Sensor On Pin I
float _x = Z (I);
val2 = DigitalRead (PITCHADJUST);
if (val2 == HIGH)
Data3 = AnalogRead (1);
PITCHADJUST_RANGE = 608 - data 3; // 608 is the middle point of pitchbend plus 1
// 0 - 16383 is the full 14 bit pitchbend range
int converted = (int) (( x - 297 + PITCHADJUST_RANGE) / MIDIPITCHSCALE);
if (_converted> 16383)
{_converted = 16383;}
if (_converted <0)
{_converted = 0;}
converted >> = 7; upperBits = (byte) ( converted & 0x7F); // Convert this 14 bit range value to LSB and MSB bytes
lower Bits = (byte) (_ converted & 0x7F)
// Now output the message
SendMIDI (0xe0, lowerBits, upperBits);
Z Float (Byte Pin)
int tmp;
int data1 = 0;
int data2 = 0;
int Summary = 0; // Summary Of Input Data
int H;
Summary = Summary + (data1); } tmp = Summary / 10; return (float) tmp; } tmp ; // get average data from analogpin0
for (h = 0; h <10; h ++) {
data1 = analogRead
void setup () {
SendMIDI ( 0xB0, 0x64, 0); SendMIDI (0xB0, 0x06, PITCH_RANGE); //
Set MIDI baud rate:
SendMIDI (0xB0, 0x65, 0 ); // MIDI.begin Set pitchbend range pinMode (SWITCH, INPUT); pinMode (PITCHADJUST, INPUT);
loop void () {
Volume ();
Bendrange ();
Cutoff ();
Control ();
ProcessAnalogValue (PITCHINPUT);
Delay (1);
Try Serial instead of serial. (capital S)
serial.write (byte
void control () {
That mess between the declaration of MIDIPITCHSCALE and the control() function - where did it come from? All executable code MUST be in a function.
Thanks for the speedy replies guys,
Paul this is Mitsushi Abe's code that seemed to of worked for him, i guess there must of been a formatting error when he copied it to his blog post? So i'm not really too sure, i'm a bit of a noob. :confused:
Hi, this is Mitsushi Abe. Do you have any problems about my Ondes Martenot MIDI Controller yet?
galliano:
I imagine after 3 years, it's no longer any issue -- one way or the other.
