Midi Out delay and strange noise Problem
Hey Guys
i have a small Problem during my Midi Out Project. Maybe somebody can help me.
scope of work: To send a note without delay via midi out on TX Port by pressing a button until its released.
Problem: If i push and hold the button principal the note signal works and is send without a delay and thats fine. I tryed it with my yamaha keyboard and its midi in port. The strange thing is that if i insert a delay after the noteOn message it sounds clear but without a delay time when i push the button it sounds first like going from a low frequency to a high very fast before i hear the right and clear tone. Could it be something with the debouncing time? Maybe somebody has an idea. Thanks :)
Here is my primitive code
const int buttonPin = 4; int buttonState = 0;
void setup() { // Set MIDI baud rate: Serial.begin(31250); pinMode(buttonPin, INPUT); }
void loop() { // play notes from F#-0 (0x1E) to F#-5 (0x5A): buttonState = digitalRead(buttonPin); { int note1 = 0x40; //Note on channel 1 (0x90), some note value (note), middle velocity (0x45): if (buttonState == HIGH){
noteOn(0x90, note1, 0x45); } else { } } }
// plays a MIDI note. Doesn't check to see that // cmd is greater than 127, or that data values are less than 127: void noteOn(int cmd, int pitch, int velocity) { Serial.write(cmd); Serial.write(pitch); Serial.write(velocity); }
I'm only beginning play with midi code but I was under the impression once you send note-on it would play until you send note-off?
Apart from that... it might also depend on how your how yamaha keyboard interprets midi signals... best bet is to add debounce...
Remember loop is looping constantly - you will be calling noteOn maybe a thousand times a second (depending on the serial clock for midi).
You need to detect button-down event and button-up event separately - you don't want to do actions everytime you see a state, just when you see the state change - ie a state-transition.
[BTW note use of code tags...]
int prev_state ;
void loop ()
  int state = digitalRead (buttonPin)
  if (state != prev_state)  // only do actions on state-changes
    prev_state = state ;   // record for next time
    if (state == HIGH)  // decide which action
      noteOff(...) ; // or whatever
