but instead of getting a sound directly out of the arduino, I want it to produce midi-notes so I can link any instrument to it.
I wrote an IDE-code that produces the midi-signals, but It's still not working as I want it to.
this is an example of the code:
#include <CapacitiveSensor.h>
CapacitiveSensor cs_2_3 = CapacitiveSensor(2,3);
CapacitiveSensor cs_2_4 = CapacitiveSensor(2,4);
int velocity = 100;//velocity of MIDI notes, must be between 0 and 127
//(higher velocity usually makes MIDI instruments louder)
int noteON = 144;//144 = 10010000 in binary, note on command
// Set MIDI baud rate:
Serial.begin(31250);
long total1 = cs_2_3.capacitiveSensor(30);
long total2 = cs_2_4.capacitiveSensor(30);
if (total1 > 500) {
for (int note=48;note<49;note++) {//from note 50 (D3) to note 69 (A4)
MIDImessage(noteON, note, velocity);//turn note on
MIDImessage(noteON, note, 0);}}//turn note off
if (total2 > 500) {
for (int note=49;note<50;note++) {//from note 50 (D3) to note 69 (A4)
delay(500);//hold note for 300ms
//send MIDI message
void MIDImessage(int command, int MIDInote, int MIDIvelocity) {
Serial.write(command);//send note on or note off command
Serial.write(MIDInote);//send pitch data
Serial.write(MIDIvelocity);//send velocity data
The problem is: It can not send 2 or more midi-notes at the same time. Probably it's because of the delay function. And when I hold/press the touchcapacitive sensor, it will sent out midi notes every 0,5s instead just one.
Is there a way the arduino can only sent out one midi-note if you press the capacitive sensor once, instead of sending out the midi-note every 0,5s?
I believe you'll need to add a variable to store the last sent note, then when you go to play a new note you compare and decide weather or not to play the note.
int lastNote = 0;
playedKey = sensor input.
if(playedKey != lastNote){ /if the note is different from the last
PlayMidi note;
lastNote = playedKey;
The probem is that you need to detect the transition from off to on and on to off, only sending the MIDI message when you see the transition (this is the EDGE detection mentioned). As has already been suggested, you need to remember the last state of the input and only act when the state is different from what it was before.
static int lastInput1 = 0;
int newInput1 = total1;
if((lastInput1 < 500) && (newInput1 > 500)) {
MIDImessage(noteON, note, ON); }};//turn note on
if((lastInput1 > 500) && (newInput1 < 500)) {
MIDImessage(noteON, note, OFF); }};
lastInput1 = newInput1;
this is just an little bit of the whole code, but so far it makes me able to play one note at the time. So first note C, when that's off, note D, etc..
The reason is your code. It needs to be able to cope with more than one note down at a time.
You need a list of times when each note up event will be triggered.
I have been playing with these sensors. I am surprised that you got so many pads working. Only 3 will work for me, after that there will be so much crosstalk and loss of sensitivity that the 4th is useless most of the time. I am using 10M resistors. Do you have a hint what you did different.
I too have the same problem as vanakaru, yet, I can only play two notes of the scale. Could you possibly post the reworked code for this as the code you posted on the instructables website is only half there!
