MIDI Out for Piezo drums sending wrong midi messages
I have re-purposed a Guitar Hero drum controller to use as a MIDI controller. Everything seems to work fine as far as the hardware goes, TX led lights, MIDI-USB box recieves signal, no problem adjusting thresholds. The problem is when I hit the drum the input monitor in http://www.midiox.com/ the input monitor gives me tons of midi off messages and system messages and seemingly random midi note on. I've tried using decimal and hexadecimal numbers for notes and it seems to continue to be random.
Here's the code I'm using:
// * SpikenzieLabs.com *
// * Drum Kit - Kit *
// BY: MARK DEMERS Copywrite 20009
// April. 2009
// VERSION: 1.b
// DESCRIPTION:
// Arduino analog input used to sense piezo drum hits then sent serialy to processing.
// Required - Hardware:
// 1. Drum kit - kit (From SpikenzieLabs.com)
// 2. Arduino
// Required - Software:
// 1. Serial MIDI converter
// 2. Garage Band, Ableton Live etc ...
// LEGAL:
// This code is provided as is. No guaranties or warranties are given in any form. It is your responsibilty to
// determine this codes suitability for your application.
// User settable variables
unsigned char PadNote[6] = {0x31,0x2d,0x30,0x2A,0x26,0x23}; // MIDI notes from 0 to 127 (Mid C = 60)
int PadCutOff[6] = {200,100,100,200,100,400}; // Minimum Analog value to cause a drum hit
int MaxPlayTime[6] = {90,90,90,90,90,90}; // Cycles before a 2nd hit is allowed
#define midichannel 0x90; // MIDI channel from 0 to 15 (+1 in "real world")
boolean VelocityFlag = true; // Velocity ON (true) or OFF (false)
// Internal Use Variables
boolean activePad[6] = {0,0,0,0,0,0}; // Array of flags of pad currently playing
int PinPlayTime[6] = {0,0,0,0,0,0}; // Counter since pad started to play
unsigned char status;
int pin = 0;
int hitavg = 0;
// Setup
Serial.begin(57600); // connect to the serial port 115200
// Main Program
for(int pin=0; pin < 6; pin++)
hitavg = analogRead(pin); // read the input pin
if((hitavg > PadCutOff[pin]))
if((activePad[pin] == false))
if(VelocityFlag == true)
// hitavg = 127 / ((1023 - PadCutOff[pin]) / (hitavg - PadCutOff[pin])); // With full range (Too sensitive ?)
hitavg = (hitavg / 8) -1 ; // Upper range
hitavg = 127;
MIDI_TX(144,PadNote[pin],hitavg);
PinPlayTime[pin] = 0;
activePad[pin] = true;
PinPlayTime[pin] = PinPlayTime[pin] + 1;
else if((activePad[pin] == true))
if(PinPlayTime[pin] > MaxPlayTime[pin])
activePad[pin] = false;
MIDI_TX(128,PadNote[pin],127);
// Transmit MIDI Message
void MIDI_TX(unsigned char MESSAGE, unsigned char PadNote, unsigned char VELOCITY)
status = MESSAGE + midichannel;
Serial.print(status);
Serial.print(PadNote);
Serial.print(VELOCITY);
Any help is much appreciated .
Did you put that smiley in your code?
Read the how to use the forum sticky post.
Drums are normally sent on MIDI channel 9 so you need to send it on the correct channel.
