midi-out PC
hello. is it possible to read the midi output of a sequencer software e.g Cubase from the arduino board? thank u.
there was some code for getting midi in on the arduino posted a while ago here :http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1152354897/15
I expect more posts can be found if you do a search
Good luck :)
hi ! the working code is here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1187962258/ note that it's hard-coded for midi-channel 1, and does not more than recognize (single) note-ons and offs.
i did a basic synth with it using the FrequOut2 library. it's a pending project, but works fine already with modulation and velocity.
kuk
hallo.could you please send me the link to the FrequOut2 library?
thank u…
ok, it's name is FrequencyTimer2. my mistake. it's in the playgorund:
http://www.arduino.cc/playground/Code/FrequencyTimer2
