MIDI - Script
Hallo,
da ich dank eurer Hilfe erst einmal weitergekommen bin, stehe ich nun vor einer neuen Herausforderung.
Den das Programmieren liegt mir nicht und im Netz habe ich folgendes Script entdeckt:
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#define KICKTHRESHOLD  20
#define SNARETHRESHOLD 20
#define HIHATTHRESHOLD  20
unsigned long snareInterval       = 10;
unsigned long previousSnareMillis = 0;
unsigned long kickInterval        = 10;
unsigned long previousKickMillis  = 0;
unsigned long hihatInterval       = 10;
unsigned long previousHihatMillis = 0;
int kickPin  = A0;
int snarePin = A1;
int hihatPin = A2;
int pedalPin = 8;
int kickValue  = 0;
int snareValue = 0;
int hihatValue = 0;
int pedalValue = 0;
boolean pedalPlayed = true;
// MAPPING FOR ADDICTIVE DRUMS
byte KICK                  = 36;
byte SNARE_RIMCLICK        = 44;
byte SNARE_SHALLOW_HIT     = 43;
byte SNARE_SIDESTICK       = 42;
byte SNARE_SHALLOW_RIMSHOT = 41;
byte SNARE_FLAM_HIT        = 40;
byte SNARE_FLAM_RIM        = 39;
byte SNARE_OPEN_HIT        = 38;
byte SNARE_RIMSHOT         = 37;
byte HIHAT_PEDAL_OPEN      = 59;
byte HIHAT_OPEN_BELL       = 58;
byte HIHAT_OPEN_D          = 57;
byte HIHAT_OPEN_C          = 56;
byte HIHAT_OPEN_B          = 55;
byte HIHAT_OPEN_A          = 54;
byte HIHAT_CLOSED_BELL     = 53;
byte HIHAT_CLOSED2_SHAFT   = 52;
byte HIHAT_CLOSED2_TIP     = 51;
byte HIHAT_CLOSED1_SHAFT   = 50;
byte HIHAT_CLOSED1_TIP     = 49;
byte HIHAT_PEDAL_CLOSED    = 48;
byte EXTRA                 = 47;
byte TOM1_RIMSHOT          = 72;
byte TOM1_HIT              = 71;
byte TOM2_RIMSHOT          = 70;
byte TOM2_HIT              = 69;
byte TOM3_RIMSHOT          = 68;
byte TOM3_HIT              = 67;
byte TOM4_RIMSHOT          = 68;
byte TOM4_HIT              = 67;
  MIDI.begin();
  pinMode(pedalPin, INPUT);
  digitalWrite(pedalPin, HIGH);
boolean noteReady(unsigned long previousMillis, unsigned long interval) {
  if((unsigned long)(millis() - previousMillis) >= interval) {
    return true;
  else {
    return false;
void hitNote(int value, byte note, int multiply, int treshold) {
  int velocity = value - treshold;
  if(velocity > 127)
    velocity = 127;
  else if(velocity < 0)
    velocity = 0;
  MIDI.sendNoteOn(note, velocity, 1);
  MIDI.sendNoteOff(note, 0, 1);
  kickValue  = analogRead(kickPin);
  snareValue = analogRead(snarePin);
  hihatValue = analogRead(hihatPin);
  pedalValue = digitalRead(pedalPin);
  if(kickValue >= KICKTHRESHOLD && noteReady(previousKickMillis, kickInterval)) {
    previousKickMillis = millis();
    hitNote(kickValue, KICK, 5, KICKTHRESHOLD);
  if(snareValue >= SNARETHRESHOLD && noteReady(previousSnareMillis, snareInterval)) {
    previousSnareMillis = millis();
    hitNote(snareValue, SNARE_OPEN_HIT, 1, SNARETHRESHOLD);
  if(hihatValue >= HIHATTHRESHOLD && noteReady(previousHihatMillis, hihatInterval)) {
    previousHihatMillis = millis();
    if(pedalValue == LOW) {
      hitNote(hihatValue, HIHAT_CLOSED1_TIP, 1, HIHATTHRESHOLD);
    else {
      hitNote(hihatValue, HIHAT_OPEN_A, 1, HIHATTHRESHOLD);
  if(pedalValue == LOW && pedalPlayed == false) {
    hitNote(127, HIHAT_PEDAL_CLOSED, 1, 0);
    pedalPlayed = true;
  if(pedalValue == HIGH)
    pedalPlayed = false;
nun nutze ich die Analogen-Pins A0 und A1 um Signale von einem Multiplexer (CD4051?) zu einem Virtuellen Schlagzeug zu senden.
Was müsste ich ändern um dem Programm mitzuteilen, das es mehrer Sensoren gibt und diese entsprechend in der Software erkennt z.B Sensoren 1 - Hi-Hat usw…?
(Wäre jemand bereit, für eine Spende, mir den Code anzupassen?)
M.f.G
Alex.W
die Hi-Hat kommt im Sketch eh schon vor. Sensor an A2 anschließen und loslegen.
Weitere Geräte einfach nach Muster der bestehenden anlegen.
Ich habe zwei Multiplexer mit je 8 Sensoren, wie ließe sich das dafür anpassen?
M.f.G
Alex.W
zunächst mal einen separaten sketch schreiben, der die zwei Multiplexer auswertet.
dann die zwei Sketche verheiraten und die Variablen setzen wo heute die Pins ausgelesen werden.
Hättest du weiterführende Links für mich, um damit vertrauter zu werden???
oder die Zeit um mir ein solches Programm zu schreiben???
M.f.G
Alex.W
nein.
nein.
Ich würde nicht Hardware einsetzen die ich nicht kenne, sondern einfach einen microcontroller nehmen der genug Eingänge hat.
Hi
Die 2.te Frage war doch nur rein rhetorisch, oder??
Nicht, daß ich den Gas-Brenner zum Teer anheizen doch noch suchen muß ...
mfG
Selbst redent, bezahle ich die mühe.
M.f.G
Alex.W
AlexW1002:
Du kannst weniger als 10000 Konversionen in voller Auflösung pro Sekunde hinbekommen.
Weiterführender Link ADC conversion on the Arduino (analogRead)
Im Moment hast du 3 analogReads pro loop,
ob die Reaktionszeit bei 16 analogReads noch ausreicht müsstest du testen, es ist ca 6 mal lahmer.
Wie man einen CD4051 benutzt kannst du hier 74HC4051 multiplexer / demultiplexer nachlesen.
