MIDI.sendControlChange(???);
Hello I am trying to achieve something like midi keypad with arduino and distance sensors.
I have four fixed notes and four distance sensors. I want to send a note with velocity( value coming from distance sensor ) to max/msp. I am using MIDI/MOCO for LUFA firmware.
The problem is that somehow it changes the positions of the components of the midi package.
In max I have displayed:
  1. MIDI channel
  2. Control number
  3. Control value
    Somehow and sometime I have control number on the place that should be control value???
    I have tried with newer and older arduino versions. Where could be the problem?
I am attaching my patch. Can anyone help me?
Thanks in advance.
#include <MIDI.h>
#include <FIRFilters.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#define a (0.07)
filters<int> f0;
filters<int> f1;
filters<int> f2;
filters<int> f3;
filters<int> f4;
filters<int> f5;
filters<int> f6;
  MIDI.begin();
  delay(10);
  pinMode( 6, OUTPUT);
  pinMode( 9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
  delay(10);
  digitalWrite( 13, HIGH );
  uint16_t sen0 = f0.EMA( analogRead( A0 ), a );
  analogWrite( 11, (sen0/4) );
  playNote0( sen0 / 2 );
  uint16_t sen1 = f1.EMA( analogRead( A1 ), a );
  analogWrite( 10, (sen1>>2) );
  playNote1( sen1 >> 1 );
  uint16_t sen2 = f2.EMA( analogRead( A2 ), a );
  analogWrite( 9, (sen2>>2) );
  playNote2( sen2 >> 1 );
  uint16_t sen3 = f3.EMA( analogRead( A3 ), a );
  analogWrite( 6, (sen3>>4) );
  playNote3( sen3 >> 1 );
  uint16_t sen4 = f4.EMA( analogRead( A4 ), a );
  analogWrite( 6, (sen4/4) );
  playNote4( sen4 >> 1 );
  uint16_t sen5 = f5.EMA( analogRead( A5 ), a );
  analogWrite( 6, (sen5>>4) );
  playNote5( sen5 >> 1 );
  uint16_t sen6 = f6.EMA( analogRead( A6 ), a );
  analogWrite( 6, (sen6>>4) );
  playNote6( sen6 >> 1 );
  delay( 10 ); //??
//-----------PLAYNOTES----------------
#define midi_channel (1)
const byte notes[7] = { 45, 60, 80, 120, 32, 36, 43 };
void playNote0( uint16_t sen )
  static boolean flag = 0;
  if( sen > 0 )
    MIDI.sendControlChange(notes[0], sen, midi_channel);
    flag = 1;
      if( sen == 0 && flag == 1 ){
        MIDI.sendControlChange(notes[0], 0, midi_channel);
        flag = 0;
void playNote1( uint16_t sen )
  if( sen > 0 )
    MIDI.sendControlChange(notes[1], sen, midi_channel);
    flag = 1;
        MIDI.sendControlChange(notes[1], 0, midi_channel);
        flag = 0;
void playNote2( uint16_t sen )
  if( sen > 0 )
    MIDI.sendControlChange(notes[2], sen, midi_channel);
    flag = 1;
        MIDI.sendControlChange(notes[2], 0, midi_channel);
        flag = 0;
void playNote3( uint16_t sen )
  if( sen > 0 )
    MIDI.sendControlChange(notes[3], sen, midi_channel);
    flag = 1;
        MIDI.sendControlChange(notes[3], 0, midi_channel);
        flag = 0;
void playNote4( uint16_t sen )
  if( sen > 0 )
    MIDI.sendControlChange(notes[4], sen, midi_channel);
    flag = 1;
        MIDI.sendControlChange(notes[4], 0, midi_channel);
        flag = 0;
void playNote5( uint16_t sen )
  if( sen > 0 )
    MIDI.sendControlChange(notes[5], sen, midi_channel);
    flag = 1;
        MIDI.sendControlChange(notes[5], 0, midi_channel);
        flag = 0;
void playNote6( uint16_t sen )
  if( sen > 0 )
    MIDI.sendControlChange(notes[6], sen, midi_channel);
    flag = 1;
        MIDI.sendControlChange(notes[6], 0, midi_channel);
        flag = 0;
Maybe you should be using MIDI.sendNoteOn(pitch, velocity, channel) and MIDI.sendNoteOff(pitch, velocity, channel); instead of MIDI.sendControlChange().
You seem to be using velocity values from 0 to 512. MIDI velocity only goes up to 127.
hmm.. I need to send control change to ableton :frowning: ..
0 512 ..? I have 0 to 1023 from the ADC. I am using 1023/4 for the analog read and then /2 for the velocity..
I saw the examples with sendControllChange this way. It seems to be a bug. I found that if I plug the usb some times it change the places of the velocity and control number as I said. But when I reset the arduino from the reset button it fixes.
