What a great place is this! I leaned a lot from this forum reading questions and answers. I learned a lot from that, thanks.
I am making a tally light system for a Roland V-8HD video mixer.
I use an Arduino Due with the native USB port for MIDI.
I have to send SysEx messages over USB to the Ronald V-8HD mixer and the video mixer sends a SysEx message back with in my case the tally light information.
I send always the same message but the sende messages are differing in length.
I read the send output in Hairless Midi 0.4
I post my code here.
I could not get the output as text from Hairless Midi, so I put is in as an attachment, sorry about that.
#include <USB-MIDI.h>
USBMIDI_CREATE_DEFAULT_INSTANCE();
unsigned long t0 = millis();
const byte SysExSendV8HdTally[] = {0xf0, 0x41, 0x10, 0x00, 0x00, 0x00, 0x68, 0x11, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x08, 0x6C, 0xF7};
// Listen for MIDI messages on channel 1
MIDI.begin(1);
// Listen to incoming Midi messages
MIDI.read();
// send SysExTally 10 times a second
if ((millis() - t0) > 100)
t0 = millis();
MIDI.sendSysEx(sizeof(SysExSendV8HdTally), SysExSendV8HdTally, true);
Sending and receiving SysEx massages with the code on an Arduino Leonardo works fine! Sending and receiving Tally inforation with Midi SysEx messages from Ronald V-8HD, routed via MidiFire on iPad, is working.
Hello, I was very interested to see your post as I also want to add Tally lights to my Roland V-8HD. Unfortunately I understand electronics and circuits but I am a beginner in software so do you have any advice for me or do you mind sharing your project? I have an Arduino Leonardo as I note that is how you made your project work.
Thank you very much!
David
Hello David, great that you are interested! I use the Tally system in our webinar studio. I am not experienced in writing code so it can be improved but it is working. I am routing USB Midi communication via an iPad acting as a USB host. The only problem nog solved is using the Arduin Tally system in combination with the V-8HD Remote app. Then USB trafic seems to interfere with each other creating USB Midi traffic to stall. With the V-8HD Remote app running in the background the Arduino Tally system for Ronald V-8HD runs flawwless.
