MIDI through on Sparkfun MIDI shield
Is it possible to use the MIDI out on a Sparkfun MIDI Shield as a MIDI through, mirroring all signal from the In directly to the out? I thought that if I included the MIDI Library v3.1 from the Playground (Arduino Playground - MIDILibrary) that it would work but my messages weren't being passed downstream.
TIA.
I am using kuki's MIDI In Basic 0.2 from the old Arduino forum:
/* Midi In Basic  0.2 // kuki 8.2007
 * listen for midi serial data, and light leds for individual notes
 IMPORTANT:
 your arduino might not start if it receives data directly after a reset, because the bootloader thinks you want to uplad a new progam.
 you might need to unplug the midi-hardware until the board is running your program. that is when that statusLed turns on.
SOMETHING ABOUT MIDI MESSAGES
 midi messages start with one status byte followed by 1 _or_ 2 data bytes, depending on the command
 example midi message: 144-36-100
   the status byte "144" tells us what to do. "144" means "note on".
   in this case the second bytes tells us which note to play (36=middle C)
   the third byte is the velocity for that note (that is how powerful the note was struck= 100)
 example midi message: 128-36
   this message is a "note off" message (status byte = 128). it is followed by the note (data byte = 36)
   since "note off" messages don't need a velocity value (it's just OFF) there will be no third byte in this case
   NOTE: some midi keyboards will never send a "note off" message, but rather a "note on with zero velocity"
 do a web search for midi messages to learn more about aftertouch, poly-pressure, midi time code, midi clock and more interesting things.
HARDWARE NOTE:
The Midi Socket is connected to arduino RX through an opto-isolator to invert the midi signal and seperate the circuits of individual instruments.
connect 8 leds to pin2-pin9 on your arduino.
//variables setup
byte incomingByte;
byte note;
byte velocity;
int statusLed = 13;   // select the pin for the LED
int action=2; //0 =note off ; 1=note on ; 2= nada
//setup: declaring iputs and outputs and begin serial
  pinMode(statusLed,OUTPUT);   // declare the LED's pin as output
  pinMode(2,OUTPUT);
  pinMode(3,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
  //start serial with midi baudrate 31250 or 38400 for debugging
  Serial.begin(31250);
  digitalWrite(statusLed,HIGH);
//loop: wait for serial data, and interpret the message
void loop () {
  if (Serial.available() > 0) {
    // read the incoming byte:
    incomingByte = Serial.read();
    // wait for as status-byte, channel 1, note on or off
    if (incomingByte== 144){ // note on message starting starting
      action=1;
    }else if (incomingByte== 128){ // note off message starting
      action=0;
    }else if (incomingByte== 208){ // aftertouch message starting
       //not implemented yet
    }else if (incomingByte== 160){ // polypressure message starting
    }else if ( (action==0)&&(note==0) ){ // if we received a "note off", we wait for which note (databyte)
      note=incomingByte;
      playNote(note, 0);
      note=0;
      velocity=0;
      action=2;
    }else if ( (action==1)&&(note==0) ){ // if we received a "note on", we wait for the note (databyte)
      note=incomingByte;
    }else if ( (action==1)&&(note!=0) ){ // ...and then the velocity
      velocity=incomingByte;
      playNote(note, velocity);
      note=0;
      velocity=0;
      action=0;
    }else{
      //nada
void blink(){
  digitalWrite(statusLed, HIGH);
  delay(100);
  digitalWrite(statusLed, LOW);
  delay(100);
void playNote(byte note, byte velocity){
  int value=LOW;
  if (velocity >10){
      value=HIGH;
  }else{
   value=LOW;
 //since we don't want to "play" all notes we wait for a note between 36 & 44
 if(note>=36 && note<44){
   byte myPin=note-34; // to get a pinnumber between 2 and 9
   digitalWrite(myPin, value);
Show us where in that code any output is being generated. All you are doing with the input is flashing an LED.
Pardon me.
I copied the wrong code. This includes MIDI.h from the Playground (Arduino Playground - MIDILibrary) at the top of the sketch, which I thought would provide MIDI through.
I see now on the Playground page that I "must call the MIDI.begin method" so I tried adding "MIDI.begin;" immediately before "Serial.begin(31250);" but got "error: statement cannot resolve address of overloaded function" when compiling.
Indeed I am not at all clear on how to arrive at mirroring signal in to out so if there is a better, simpler, or smarter way to do this with the MIDI Shield then I am entirely grateful.
(I would post MIDI.h code but it exceeds the maximum allowable of characters per post.)
 IMPORTANT:
HARDWARE NOTE:
//variables setup
byte incomingByte;
byte note;
byte velocity;
  #include <MIDI.h>
  pinMode(2,OUTPUT);
  pinMode(3,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
void loop () {
      action=1;
      action=0;
      note=incomingByte;
      playNote(note, 0);
      note=0;
      velocity=0;
      action=2;
      note=incomingByte;
      note=0;
      velocity=0;
      action=0;
    }else{
      //nada
void blink(){
  delay(100);
  delay(100);
  int value=LOW;
  if (velocity >10){
      value=HIGH;
  }else{
   value=LOW;
Notice that Serial.begin() has parentheses and a value between them, whereas MIDI.begin does not.
