Hi
I am new to Arduino's but willing to learn. I need to know what will work best and then I can learn about it, knowing that I am not chasing my tail.
My Project
I would like to receive 36 different MIDI note on signals, live, from a live MIDI keyboard). I would like to convert the signals into on/off data and send this via R.F., to 36 remote boards. One board for each note. I accept that there will be latency but would like it to be as low as possible
My Questions
What is the best board to receive the MIDI and output it as on/off data via R.F?
What is the best board to receive this data via R.F.
Then you need to broadcast an encoded message, and have N receivers each with a unique address or identifier, so it would respond only to messages meant for it.
A simple cheap solution would be one dumb 433 transmitter and N dumb 433 receivers. RadioHead library can make it easy to set up.
There may be regulatory issues where you are doing this.
There are many other radio sets that can be one-to-many configured, they get more spendy, but none would be hard to use, if you just let RadioHead do the heaviest part of the lift.
