Hello, I have searched, but either don't find the solution I'm looking for, or find overly complex projects.
Possible what I want isn't as easy as I hope?
I would like to use a Arduino Leanardo to accept data from a MIDI music keyboard, and send to a PC via the USB port. Just that.
Sounds simple, but is that not the case?
Many thanks in advance,
Paul
You can use this example from the Control Surface library: MIDI_Pipes-Routing.ino
You can leave out the line that loops back the USB MIDI interface to itself.
Pieter
What sort of interface does the MIDI keyboard present?
If it is USB then no you can’t do it with a Leonardo. If it is a 5pin DIN plug ten you can.
Pagus
April 21, 2020, 9:25pm
4
Assuming the MIDI keyboard has DIN connectors, search amazon or ebay for "midi to usb adapter". No Arduino required.
Try a really simple solution first. Assuming the keyboard has DIN connector, hook it up like this but connect midi pin 5 to arduino pin 2 instead.
In the Arduino IDE, select Tools -> USB Type -> MIDI (not sure it is available for Leonardo).
Use this simple code. It simply pipes received serial midi on pin 2 to standard serial on the USB:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
Serial.begin(31250);
mySerial.begin(31250);
if (mySerial.available())
Serial.write(mySerial.read());
