MIDI to VMDX
I am a newbie who has problems with a simple sketch. I don't know where the problem is originating from, either programming or the electronics. My sketch is a simple loop that sends a signal on PIN 2 and simultaneously sends MIDI information to the computer (VDMX - a vj software on the mac).
I have 2 Arduino chips, both exhibit the same problem. I have flashed the Arduinos to install HIDUINO and I keep having the problem. The Arduino either handles the MIDI or the PIN 2 just fine. However, when it tries to do both, it keeps reliably sending the PIN 2 information, but the MIDI stops after a limited number of cycles (under a minute most of the time). The TX light switches on on the Arduino and no more MIDI signal is sent out. If I restart the Arduino, the MIDI works reliably for a limited number of cycles.
Here is the code:
const int solenoidPin = 2;
void setup() { pinMode(solenoidPin, OUTPUT);//initialize solenoid output (through transistor then relay) Serial.begin(31250); //send an receive to computer MIDI note
digitalWrite(solenoidPin, HIGH); noteOn(0x90,60,0x45); //Note on channel 1 (0x90), note value (60), middle velocity (0x45): delay(300); noteOn(0x90,60,0x00); //Note on channel 1 decreases to 0 delay(1050);
digitalWrite(solenoidPin, LOW); noteOn(0x90,60,0x45); // note value (60) delay(300); noteOn(0x90,60,0x00);//Note on channel 1 decreases to 0 delay(1000); }
void noteOn(int cmd, int pitch, int velocity) { Serial.write(cmd); Serial.write(pitch); Serial.write(velocity); }
What, exactly, is connected to this pin? The more details, the better.
The TX light stays on? Or, was one of those ons supposed to be an off?
