Hello everyone, I'm from Brazil.
I have a DX7 MK1 that generates a MIDI OUT speed of 100, I need hardware that converts this to 127, as I intend to control other modules from the DX7.
I discovered a MIDI cable that accepts Arduino codes, RK-002 Smart MIDI cable, this was the most accessible and low-cost option I found. Pocket Curve Anatek and MIDI Solutions are expensive here in Brazil
Is it possible to do this, what would be the code to be used.
0 - 100 to 0 - 127
There is an example in the link that I gave. Instead of using analogRead() to store a value in val, val is now the value that you received over midi; in below I called it midiVal.
