Hi there! As far as I know the new Arduino's FTDI can be programmed to appear as a MIDI device. Any ideas how to get started?
You referring to the Uno? If so, then, no, it's FTDI can not be programmed, since the Uno doesn't have a FTDI chip.
Hi alkopop79,
I use Reason and have been wanting to develop usb based MIDI controllers with the Arduino.
After exhaustive search on Windows driver writing I have concluded that it is possible, but will require some very serious programming.
With any version of Windows before 7 you would have to write a Kernel mode driver... something that should only be attempted by advanced programmers.
If you are using a Mac, there are applications that can re-identify your USB input as a Midi input. I have not had a chance to test them.
Let us know if you find out anything... I would guess that it won't be long before some advanced programmer writes a driver for Arduino to usb Midi. I wish I knew enough to attempt it.
-Miles
