'MIDI' was not declared in this scope
Hi all!
I’m new with Arduino and might need some help. I keep receiving this message while I try to upload my sketch to the Arduino board. I’ve got the MIDI library installed so I don’t understand why the sketch wont read it.
‘MIDI’ was not declared in this scope
Here is a sample of my code:
// include MIDI library
#include <MIDI.h>
// read digital pins number 2, 4, 7
int pushButton2 = 2;
int pushButton4 = 4;
int pushButton7 = 7;
// checks if the button is pressed
int buttonState2 = 0;
int buttonState4 = 0;
int buttonState7 = 0;
// play/stop notes in relation to buttons pressed
int note2 = 0;
int note4 = 0;
int note7 = 0;
// read potentiometer value
int analogValue = 0;
// maximum MIDI value is 127, first/previous potentiometer
// move has to always be different than previous value
int lastAnalogValue = 128;
MIDI.begin(4);
// 115200 hairless MIDI
pinMode(pushButton2, INPUT);
pinMode(pushButton4, INPUT);
pinMode(pushButton7, INPUT);
Somebody can give me a clue about what’s happening?
Thank you!
I've got the MIDI library installed so I don't understand why the sketch wont read it.
Two possibilities. One, you put it in the wrong place. Two, you didn't restart the IDE after installing the library.
Hey! Thanks for your reply!
The strange thing is when I upload one of the examples included on the MIDI library, everything goes smoothly. It's just when I try to upload any other sketch which isn't on the library!
Any idea?
Many thanks!
What do the #include statements in the code that does compile look like?
I think it’s all fine in the code! Here’s a copy!
#include <MIDI.h>
int note2 = 0;
int note4 = 0;
int note7 = 0;
MIDI.begin(4);
// read state of buttons
int buttonState2 = digitalRead(pushButton2);
int buttonState4 = digitalRead(pushButton4);
int buttonState7 = digitalRead(pushButton7);
// Analog potentiometer
// potentiometer gives values up to 1023
// we need values not bigger than 127
int analogValue = analogRead(A0)/8;
// potentiometer could be too sensitive and
// give different (±1) values.
// send CC only when the difference between last value
// is more than 1
if ((analogValue-lastAnalogValue) > 1 || (analogValue-lastAnalogValue) < -1) {
// value changed?
if (analogValue != lastAnalogValue) {
// send serial value (ControlNumber 1, ControlValue = analogValue, Channel 1)
// more info: Arduino MIDI Library: MIDI_Class Class Reference
MIDI.sendControlChange(1, analogValue, 1);
lastAnalogValue = analogValue;
// Button 2
// when button pressed:
if (buttonState2 == HIGH) {
// if note not playing
if (note2 == 0) {
// play note (note number, velocity, channel)
// MIDI notes chart http://www.phys.unsw.edu.au/jw/notes.html
// 55 = G3, 127 = trigger note with max volume
MIDI.sendNoteOn(55,127,1);
// note is playing
note2 = 1;
// when button released
// if note playing
if (note2 == 1) {
// if playing - stop
MIDI.sendNoteOff(55,0,1);
// if button released note is off
note2 = 0;
// Button 4
if (buttonState4 == HIGH) {
if (note4 == 0) {
MIDI.sendNoteOn(63,127,1);
note4 = 1;
if (note4 == 1) {
MIDI.sendNoteOff(63,0,1);
note4 = 0;
// Button 7
if (buttonState7 == HIGH) {
if (note7 == 0) {
MIDI.sendNoteOn(60,127,1);
note7 = 1;
if (note7 == 1) {
MIDI.sendNoteOff(60,0,1);
note7 = 0;
delay(1);
And a screenshot showing the error…
And a screenshot showing the error...
That wasn't what I asked. Try again.
I made it work. Just opened a example file and copied the code into it. It worked!
Still don’t understand why wont accept the initial #include <MIDI.h> statement …
hi guys I wrote these lines on the code and works
MIDI_CREATE_DEFAULT_INSTANCE();
after include the MIDI library
OMG, RodolfoCorichi: thank you so much, that worked!
