MIDID controlled Solenoids
Hey,
Im working on a solenoid orchestra. I am bringing MIDI from Ableton Live into Max, then sending serial messages to Arduino. running the code below. The problem occurs when solenoids are triggered by the midi. Instead of striking once but they strike repeatedly until a different MIDI signal is sent.
Any suggestions would be greatly appreciated. Ive been working on this for a while and con not figure it out. I have a feeling it has to do with the delays but Im not sure.
/////////////////////////////////SOLENOID ORCHESTRA\\\\\\\\\\\\\\\\\
6 24Watt Solenoids controlled by external MIDI
2011 Michael Manning
The circuit:
  • Solenoid 1 to digital pin 8
  • Solenoid 2 to digital pin 9
  • Solenoid 3 to digital pin 10
  • Solenoid 4 to digital pin 11
  • Solenoid 5 to digital pin 12
  • Solenoid 6 to digital pin 13
  • 10K resistors to digital pins
//---------------------------------VARS------------------------------------------
int serialvalue; // value for serial input
int SPins[] = {8, 9, 10, 11, 12 ,13};
//---------------------------------SETUP------------------------------------------
void setup(){
for (int thisS = 0; thisS < 6; thisS++) { // initialize pins
pinMode(SPins[thisS], OUTPUT);
Serial.begin(9600); // open the arduino serial port
//---------------------------------LOOP------------------------------------------
void loop(){
if(Serial.available()) // check to see if there's serial data in the buffer
serialvalue = Serial.read(); // read a byte of serial data
if (serialvalue == 60){
Serial.print(serialvalue); // echo the received serial value
solenoidStrike (11);
void solenoidStrike (int pinNumber) {
digitalWrite(pinNumber, HIGH); // set the LED on
delay(80); // wait for a second
digitalWrite(pinNumber, LOW); // set the LED off
Maybe try using the MIDI library
for Midi use 31250 as speed instead of 9600.
The better is to use note on / note off midi message to control the sellenoid. It exist labraries and a lot of samples in this site.
No idea about whether you would be better off with the MIDI libraries - never used them.
However, your immediate problem is this: Every time loop runs, you look for something from the serial port. If there is anything, you read it into SerialValue. Then you check if it's 60 and when it is, strike the solenoid. However, you never reset SerialValue, so next time round loop, if there's nothing sent to the serial port, nothing will be read, but SerialValue will still be 60, so the solenoid will get struck again (and again next loop..), until there is some serial data to read.
Set SerialValue to zero immediately after you strike the solenoid
