MidiDrum add LCDI2C then no sound
First my MidiDrum has sound without LCDI2C. Then I added the LCDI2C and five buttons (Edit, Up, Down, Next, Back) to my code, but it was no sound when hit any pad. Also press the five buttons and it’s no any action. Is the code wrong? I’m using Arduino Mega2560.
byte KICK[6] = {
  100, //sensitivity (1-100)
  55,  //threshold (1-100)
  25,  //scan time (1-)
  30,  //mask time(1-)
  36,  //note (0-127)
  1    //curve type(0-4)
byte TOM1[6] = {100, 55, 25, 30, 71, 1};
byte TOM2[6] = {100, 10, 10, 30, 69, 1};
#include <hellodrum.h>
//Using MIDI Library. If you want to use USB-MIDI, comment out the next two lines.
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
LiquidCrystal_I2C lcd(0x27, 16, 2);
//Please name your piezo.
HelloDrum kick(0);
HelloDrum tom1(1);
HelloDrum tom2(2);
HelloDrumButton button(22, 24, 26, 28, 30); //(EDIT,UP,DOWN,NEXT,BACK)
  lcd.init(); // initialize the lcd
  lcd.backlight();  //open the backlight
  MIDI.begin();
  Serial.begin(38400);
  kick.settingName("KICK");
  tom1.settingName("TOM 1");
  tom2.settingName("TOM 2");
  kick.loadMemory();
  tom1.loadMemory();
  tom2.loadMemory();
  lcd.clear();
  lcd.setCursor(3, 0);
  lcd.print("Hello Drum");
  /////////// LCD & SETTING MODE /////////////
  bool buttonPush = button.GetPushState();
  bool editStart = button.GetEditState();
  bool editDone = button.GetEditdoneState();
  bool display = button.GetDisplayState();
  const char *padName  = button.GetPadName();
  const char *item = button.GetSettingItem();
  int settingValue = button.GetSettingValue();
  int velocity = button.GetVelocity();
  const char *hitPad = button.GetHitPad();
  button.readButtonState();
  kick.settingEnable();
  tom1.settingEnable();
  tom2.settingEnable();
  if (buttonPush == true)
    lcd.clear();
    lcd.print(padName);
    lcd.setCursor(0, 1);
    lcd.print(item);
    lcd.setCursor(13, 1);
    lcd.print(settingValue);
  if (editStart == true)
    lcd.clear();              // clear display
    lcd.print("EDIT START");  // print message at (0, 0)
    delay(500);               // display the above for 0.5 seconds
    lcd.print(padName);       // print message at (0, 0)
    lcd.setCursor(0, 1);      // move cursor to   (0, 1)
    lcd.print(item);          // print message at (0, 01)
    lcd.setCursor(13, 1);     // move cursor to   (13, 1)
    lcd.print(settingValue);  // print message at (13, 1)
  if (editDone == true)
    lcd.clear();
    lcd.print("EDIT DONE");
    lcd.clear();
    lcd.print(padName);
    lcd.print(item);
  //show hitted pad name and velocity to LCD
  //Immediately after I2C communication, scanning of piezo is stop.
  kick.singlePiezo();
  tom1.singlePiezo();
  tom2.singlePiezo();
  //MIDI signals are transmitted with this IF statement.
  //For each piezo, one IF statement is required
  //kick
  if (kick.hit == true)
    MIDI.sendNoteOn(KICK[4], kick.velocity, 10); //(note, velocity, channel)
    MIDI.sendNoteOff(KICK[4], 0, 10);
  //tom 1
  if (tom1.hit == true)
    MIDI.sendNoteOn(TOM1[4], tom1.velocity, 10); //(note, velocity, channel)
    MIDI.sendNoteOff(TOM1[4], 0, 10);
  //tom 2
  if (tom2.hit == true)
    MIDI.sendNoteOn(TOM2[4], tom2.velocity, 10); //(note, velocity, channel)
    MIDI.sendNoteOff(TOM2[4], 0, 10);
I suspect that some of your buttons use the SCL/SDA pins of the I2C bus.
Do you mean button(22, 24, 26, 28, 30) the SCL/SDA pins of the I2C bus?
LCDI2C display normal, but no any action when hit any buttons, also with no sound, I think code of buttons make some error and cause no sound.
I have no idea about your libraries, cannot help you further.
