Here it is:
#include <pitchToNote.h>
#include <MIDI.h>
#include "Controller.h"
MIDI CONTROLLER
by Notes and Volts
www.notesandvolts.com
Version 1.2 **Arduino UNO ONLY!**
MIDI_CREATE_DEFAULT_INSTANCE();
//***SET THE NUMBER OF CONTROLS USED**************************
//---How many buttons are connected directly to pins?---------
byte NUMBER_BUTTONS = 2;
//---How many potentiometers are connected directly to pins?--
byte NUMBER_POTS = 0;
//---How many buttons are connected to a multiplexer?---------
byte NUMBER_MUX_BUTTONS = 0;
//---How many potentiometers are connected to a multiplexer?--
byte NUMBER_MUX_POTS = 0;
//***ANY MULTIPLEXERS? (74HC4067)************************************
//MUX address pins must be connected to Arduino UNO pins 2,3,4,5
//A0 = PIN2, A1 = PIN3, A2 = PIN4, A3 = PIN5
//Mux NAME (OUTPUT PIN, , How Many Mux Pins?(8 or 16) , Is It Analog?);
//Mux M1(10, 16, false); //Digital multiplexer on Arduino pin 10
//Mux M2(A5, 8, true); //Analog multiplexer on Arduino analog pin A0
//***DEFINE DIRECTLY CONNECTED POTENTIOMETERS************************
//Pot (Pin Number, Command, CC Control, Channel Number)
//**Command parameter is for future use**
//Pot PO1(A0, 0, 1, 1);
//Pot PO2(A1, 0, 10, 1);
//Pot PO3(A2, 0, 22, 1);
//Pot PO4(A3, 0, 118, 1);
//Pot PO5(A4, 0, 30, 1);
//Pot PO6(A5, 0, 31, 1);
//Add pots used to array below like this-> Pot *POTS[] {&PO1, &PO2, &PO3, &PO4, &PO5, &PO6};
Pot *POTS[] {};
//***DEFINE DIRECTLY CONNECTED BUTTONS*******************************
//Button (Pin Number, Command, Note Number, Channel, Debounce Time)
//** Command parameter 0=NOTE 1=CC 2=Toggle CC **.
uint8_t upOctave = 4;
uint8_t dnOctave = 5;
uint8_t notes[] = {pitchC4, pitchD4};
Button BU1(2, 0, notes[0], 1, 5 );
Button BU2(3, 0, notes[1], 1, 5 );
//Button BU3(4, 0, 62, 1, 5 );
//Button BU4(5, 0, 63, 1, 5 );
//Button BU5(6, 0, 64, 1, 5 );
//Button BU6(7, 0, 65, 1, 5 );
//Button BU7(8, 1, 64, 1, 5 );
//Button BU8(9, 2, 64, 1, 5 );
//Add buttons used to array below like this-> Button *BUTTONS[] {&BU1, &BU2, &BU3, &BU4, &BU5, &BU6, &BU7, &BU8};
Button *BUTTONS[] {&BU1, &BU2};
//***DEFINE BUTTONS CONNECTED TO MULTIPLEXER*************************
//Button::Button(Mux mux, byte muxpin, byte command, byte value, byte channel, byte debounce)
//Button MBU1(M1, 0, 0, 70, 1, 5);
//Button MBU2(M1, 1, 1, 71, 1, 5);
//Button MBU3(M1, 2, 2, 72, 1, 5);
//Button MBU4(M1, 3, 0, 73, 1, 5);
//Button MBU5(M1, 4, 0, 74, 1, 5);
//Button MBU6(M1, 5, 0, 75, 1, 5);
//Button MBU7(M1, 6, 0, 76, 1, 5);
//Button MBU8(M1, 7, 0, 77, 1, 5);
//Button MBU9(M1, 8, 0, 78, 1, 5);
//Button MBU10(M1, 9, 0, 79, 1, 5);
//Button MBU11(M1, 10, 0, 80, 1, 5);
//Button MBU12(M1, 11, 0, 81, 1, 5);
//Button MBU13(M1, 12, 0, 82, 1, 5);
//Button MBU14(M1, 13, 0, 83, 1, 5);
//Button MBU15(M1, 14, 0, 84, 1, 5);
//Button MBU16(M1, 15, 0, 85, 1, 5);
////Add multiplexed buttons used to array below like this-> Button *MUXBUTTONS[] {&MBU1, &MBU2, &MBU3, &MBU4, &MBU5, &MBU6.....};
Button *MUXBUTTONS[] {};
//***DEFINE POTENTIOMETERS CONNECTED TO MULTIPLEXER*******************
//Pot::Pot(Mux mux, byte muxpin, byte command, byte control, byte channel)
//Pot MPO1(M2, 0, 0, 1, 1);
//Pot MPO2(M2, 1, 0, 7, 1);
//Pot MPO3(M2, 2, 0, 50, 1);
//Pot MPO4(M2, 3, 0, 55, 2);
//Pot MPO5(M2, 4, 0, 50, 1);
//Pot MPO6(M2, 5, 0, 55, 2);
//Pot MPO7(M2, 6, 0, 50, 1);
//Pot MPO8(M2, 7, 0, 55, 2);
//Pot MPO9(M2, 8, 0, 50, 1);
//Pot MPO10(M2, 9, 0, 55, 2);
//Pot MPO11(M2, 10, 0, 50, 1);
//Pot MPO12(M2, 11, 0, 55, 2);
//Pot MPO13(M2, 12, 0, 50, 1);
//Pot MPO14(M2, 13, 0, 55, 2);
//Pot MPO15(M2, 14, 0, 50, 1);
//Pot MPO16(M2, 15, 0, 55, 2);
//Add multiplexed pots used to array below like this-> Pot *MUXPOTS[] {&MPO1, &MPO2, &MPO3, &MPO4, &MPO5, &MPO6.....};
Pot *MUXPOTS[] {};
MIDI.begin(MIDI_CHANNEL_OFF);
pinMode(upOctave, INPUT_PULLUP);
pinMode(dnOctave, INPUT_PULLUP);
if(digitalRead(upOctave) == LOW){
updateOctaveUp();
if(digitalRead(dnOctave) == LOW){
updateOctaveDown();
if (NUMBER_BUTTONS != 0) updateButtons();
if (NUMBER_POTS != 0) updatePots();
if (NUMBER_MUX_BUTTONS != 0) updateMuxButtons();
if (NUMBER_MUX_POTS != 0) updateMuxPots();
//Stub
void updateOctaveUp(){
Serial.println("UP");
//Stub
void updateOctaveDown(){
Serial.println("DOWN");
void updateButtons() {
// Cycle through Button array
for (int i = 0; i < NUMBER_BUTTONS; i = i + 1) {
byte message = BUTTONS[i]->getValue();
// Button is pressed
if (message == 0) {
switch (BUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
case 1: //CC
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
case 2: //Toggle
if (BUTTONS[i]->Btoggle == 0) {
BUTTONS[i]->Btoggle = 1;
else if (BUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
BUTTONS[i]->Btoggle = 0;
// Button is not pressed
if (message == 1) {
case 0:
MIDI.sendNoteOff(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
case 1:
void updateMuxButtons() {
// Cycle through Mux Button array
for (int i = 0; i < NUMBER_MUX_BUTTONS; i = i + 1) {
MUXBUTTONS[i]->muxUpdate();
byte message = MUXBUTTONS[i]->getValue();
if (message == 0) {
switch (MUXBUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
case 1: //CC
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
case 2: //Toggle
if (MUXBUTTONS[i]->Btoggle == 0) {
MUXBUTTONS[i]->Btoggle = 1;
else if (MUXBUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
MUXBUTTONS[i]->Btoggle = 0;
if (message == 1) {
case 0:
MIDI.sendNoteOff(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
case 1:
void updatePots() {
for (int i = 0; i < NUMBER_POTS; i = i + 1) {
byte potmessage = POTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(POTS[i]->Pcontrol, potmessage, POTS[i]->Pchannel);
void updateMuxPots() {
for (int i = 0; i < NUMBER_MUX_POTS; i = i + 1) {
MUXPOTS[i]->muxUpdate();
byte potmessage = MUXPOTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(MUXPOTS[i]->Pcontrol, potmessage, MUXPOTS[i]->Pchannel);
and here are the error messages:
In file included from d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:17:0:
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:18:2: error: #error MIDIUSB can only be used with an USB MCU.
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:129:2: error: 'EndpointDescriptor' does not name a type; did you mean 'MIDIJackinDescriptor'?
EndpointDescriptor len; // 9
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:158:2: error: 'IADDescriptor' does not name a type; did you mean 'MIDI_EPDescriptor'?
IADDescriptor iad;
MIDI_EPDescriptor
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:160:2: error: 'InterfaceDescriptor' does not name a type; did you mean 'MIDI_ASInterfaceDescriptor'?
InterfaceDescriptor Audio_ControlInterface;
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:164:2: error: 'InterfaceDescriptor' does not name a type; did you mean 'MIDI_ASInterfaceDescriptor'?
InterfaceDescriptor Audio_StreamInterface;
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:212:1: error: expected class-name before '{' token
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:226:21: error: 'USBSetup' has not been declared
int getDescriptor(USBSetup& setup);
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:228:14: error: 'USBSetup' has not been declared
bool setup(USBSetup& setup);
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp: In member function 'int MIDI_::getInterface(uint8_t*)':
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:19:28: error: 'pluggedInterface' was not declared in this scope
#define MIDI_AC_INTERFACE pluggedInterface // MIDI AC Interface
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:44:9: note: in expansion of macro 'MIDI_AC_INTERFACE'
D_IAD(MIDI_AC_INTERFACE, 2, MIDI_AUDIO, MIDI_AUDIO_CONTROL, 0),
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:19:28: note: suggested alternative: 'getInterface'
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:44:3: error: 'D_IAD' was not declared in this scope
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:45:3: error: 'D_INTERFACE' was not declared in this scope
D_INTERFACE(MIDI_AC_INTERFACE,0,MIDI_AUDIO,MIDI_AUDIO_CONTROL,0),
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:45:3: note: suggested alternative: 'D_AS_INTERFACE'
D_AS_INTERFACE
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:22:27: error: 'pluggedEndpoint' was not declared in this scope
#define MIDI_ENDPOINT_OUT pluggedEndpoint
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:191:10: note: in definition of macro 'D_MIDI_JACK_EP'
{ 9, 5, _addr,_attr,_packetSize, 0, 0, 0}
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:53:35: note: in expansion of macro 'MIDI_ENDPOINT_OUT'
D_MIDI_JACK_EP(USB_ENDPOINT_OUT(MIDI_ENDPOINT_OUT),USB_ENDPOINT_TYPE_BULK,MIDI_BUFFER_SIZE),
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:53:18: error: 'USB_ENDPOINT_OUT' was not declared in this scope
{ 9, 5, addr,attr,packetSize, 0, 0, 0}
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:53:18: note: suggested alternative: 'MIDI_ENDPOINT_OUT'
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:53:54: error: 'USB_ENDPOINT_TYPE_BULK' was not declared in this scope
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:191:16: note: in definition of macro 'D_MIDI_JACK_EP'
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:55:18: error: 'USB_ENDPOINT_IN' was not declared in this scope
D_MIDI_JACK_EP(USB_ENDPOINT_IN(MIDI_ENDPOINT_IN),USB_ENDPOINT_TYPE_BULK,MIDI_BUFFER_SIZE),
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:55:18: note: suggested alternative: 'MIDI_ENDPOINT_IN'
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:58:9: error: 'USB_SendControl' was not declared in this scope
return USB_SendControl(0, &midiInterface, sizeof(midiInterface));
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp: At global scope:
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:61:19: error: 'bool MIDI::setup' is not a static data member of 'class MIDI'
bool MIDI::setup(USBSetup& setup attribute((unused)))
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:61:19: error: 'USBSetup' was not declared in this scope
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:61:19: note: suggested alternative: 'setup'
setup
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:67:26: error: 'int MIDI::getDescriptor' is not a static data member of 'class MIDI'
int MIDI::getDescriptor(USBSetup& setup attribute((unused)))
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:67:26: error: 'USBSetup' was not declared in this scope
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:67:26: note: suggested alternative: 'setup'
setup
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp: In member function 'void MIDI::accept()':
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:25:17: note: in expansion of macro 'MIDI_ENDPOINT_OUT'
#define MIDI_RX MIDI_ENDPOINT_OUT
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:90:22: note: in expansion of macro 'MIDI_RX'
if (!USB_Available(MIDI_RX)) {
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:90:8: error: 'USB_Available' was not declared in this scope
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:90:8: note: suggested alternative: 'available'
available
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:96:16: note: in expansion of macro 'MIDI_RX'
c = USB_Recv(MIDI_RX, &event, sizeof(event) );
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:96:7: error: 'USB_Recv' was not declared in this scope
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp: In member function 'midiEventPacket_t MIDI::read()':
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:124:31: note: in expansion of macro 'MIDI_RX'
if (USB_Available(MIDI_RX)) {
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:124:17: error: 'USB_Available' was not declared in this scope
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:124:17: note: suggested alternative: 'available'
available
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp: In member function 'void MIDI::flush()':
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:23:37: error: 'pluggedEndpoint' was not declared in this scope
#define MIDI_ENDPOINT_IN ((uint8_t)(pluggedEndpoint+1))
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:26:17: note: in expansion of macro 'MIDI_ENDPOINT_IN'
#define MIDI_TX MIDI_ENDPOINT_IN
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:144:12: note: in expansion of macro 'MIDI_TX'
USB_Flush(MIDI_TX);
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:144:2: error: 'USB_Flush' was not declared in this scope
USB_Flush(MIDI_TX);
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp: In member function 'size_t MIDI::write(const uint8_t*, size_t)':
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:167:20: note: in expansion of macro 'MIDI_TX'
int r = USB_Send(MIDI_TX, buffer, size);
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:167:11: error: 'USB_Send' was not declared in this scope
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:167:11: note: suggested alternative: 'USBS0'
USBS0
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp: In constructor 'MIDI::MIDI()':
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:190:22: error: class 'MIDI' does not have any field named 'PluggableUSBModule'
MIDI::MIDI(void) : PluggableUSBModule(2, 2, epType)
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:29:33: error: 'EP_TYPE_BULK_OUT' was not declared in this scope
#define EP_TYPE_BULK_OUT_MIDI EP_TYPE_BULK_OUT
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:192:14: note: in expansion of macro 'EP_TYPE_BULK_OUT_MIDI'
epType[0] = EP_TYPE_BULK_OUT_MIDI; // MIDI_ENDPOINT_OUT
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:29:33: note: suggested alternative: 'EP_TYPE_BULK_OUT_MIDI'
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:28:32: error: 'EP_TYPE_BULK_IN' was not declared in this scope
#define EP_TYPE_BULK_IN_MIDI EP_TYPE_BULK_IN
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:193:14: note: in expansion of macro 'EP_TYPE_BULK_IN_MIDI'
epType[1] = EP_TYPE_BULK_IN_MIDI; // MIDI_ENDPOINT_IN
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.h:28:32: note: suggested alternative: 'EP_TYPE_BULK_IN_MIDI'
d:\Arduino\Sketches\libraries\MIDIUSB\src\MIDIUSB.cpp:194:2: error: 'PluggableUSB' was not declared in this scope
PluggableUSB().plug(this);
exit status 1
Compilation error: exit status 1
