Hi, im trying to use the MIDIUSB library, on Arduino Leonardo with Bluetooth HC06, wich is connected on 0,1 pins.
If I use with Arduino UNO, it works fine, but with Leonardo it isn't work.
There are some special configuration that I need to do on Leonardo?
You have to use Serial1 instead of Serial. Serial on the Leonardo is USB CDC Serial, Serial1 is the UART on pins 0 and 1.
Pieter
PieterP:
Pieter
Ok, but where can I change to Serial1? MIDIUSB.h is different from MIDI.h. On MIDI.h we can change the hardwareserial (MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI)
but with MIDIUSB.h i didn't find it
MIDIUSB has nothing to do with Serial, it uses the USB connection.
Serial1 is for your Bluetooth module.
