I want to add a Midiusb out port for my 61 key keyboard.
Using Arduino Micro 5V
I found a promising project that had the correct code.
I uploaded the program for the micro.
The program works fine, but it has a very strange "feature".
Without pluged the piano ribbons, it constantly sends midi signals.
Listening to the computer, I could only understand something when I slowed down.
Unfortunately, I do not have the deep knowledge to solve such a problem.
Can anyone help with this?
Here is the code:
// works with keyboards with matrix 7x8
#define matrix1 7
#define matrix2 8
#include "MIDIUSB.h"
int octave = 0; // add or subtract 8 for one octave
bool currentState[matrix1 * matrix2];
bool requestState[matrix1 * matrix2];
//-----matrix1 number of pins-------
pinMode(A0, INPUT); //1
pinMode(A1, INPUT); //2
pinMode(A2, INPUT); //3
pinMode(A3, INPUT); //4
pinMode(14, INPUT); //5
pinMode(15, INPUT); //6
pinMode(16, INPUT); //7
//-----matrix2 number of pins-------
//each matrix2 pin must be one above the previous one
pinMode(2, INPUT); //1
pinMode(3, INPUT); //2
pinMode(4, INPUT); //3
pinMode(5, INPUT); //4
pinMode(6, INPUT); //5
pinMode(7, INPUT); //6
pinMode(8, INPUT); //7
pinMode(9, INPUT); //8
readKeys();
writeKeys();
delay(1);
void readKeys()
for (int i = 0; i < matrix2; i++)
//---------matrix2 pins-----------
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, INPUT);
pinMode(5, INPUT);
pinMode(6, INPUT);
pinMode(7, INPUT);
pinMode(8, INPUT);
pinMode(9, INPUT);
pinMode(i + 2, OUTPUT); // <--i+2 (this is your first pin number)
digitalWrite(i, LOW);
delayMicroseconds(1000);
//you have to repeat this finction matrix1 times
requestState[i * matrix1 + 0] = !digitalRead(A3);
requestState[i * matrix1 + 1] = !digitalRead(A2);
requestState[i * matrix1 + 2] = !digitalRead(A1);
requestState[i * matrix1 + 3] = !digitalRead(A0);
requestState[i * matrix1 + 4] = !digitalRead(15);
requestState[i * matrix1 + 5] = !digitalRead(14);
requestState[i * matrix1 + 6] = !digitalRead(16);
void writeKeys()
for (int i = 0; i < matrix1 * matrix2; i++)
if (requestState[i] == true && currentState[i] == false)
noteOn(0, 36 + octave + (i * matrix2) % matrix1 * matrix2 + i / matrix1, 64);
currentState[i] = requestState[i];
if (requestState[i] == false && currentState[i] == true)
noteOff(0, 36 + octave + (i * matrix2) % matrix1 * matrix2 + i / matrix1, 64);
MidiUSB.flush();
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
