MIDIUSB restart issues
I'm using the MIDI USB (SAMD21) code as a host converter.
All works well. However whenever I disconnect my MIDI keyboard and plug it back in, the host will not work unless the chip is reset again. This isn't great as I need to account for power being turned on first, and then a MIDI controller being plugged in second.
Any suggestions?
 * USB-MIDI to Legacy Serial MIDI converter
 * Copyright (C) 2012-2017 Yuuichi Akagawa
 * Idea from LPK25 USB-MIDI to Serial MIDI converter
 *   by Collin Cunningham - makezine.com, narbotic.com
 * This is sample program. Do not expect perfect behavior.
#include <usbh_midi.h>
#include <usbhub.h>
#ifdef USBCON
#define _MIDI_SERIAL_PORT Serial1
#else
#endif
// MIDI Pin assign
// 2 : GND
// 4 : +5V(Vcc) with 220ohm
// 5 : TX
USBHost UsbH;
USBH_MIDI  Midi(&UsbH);
void MIDI_poll();
void doDelay(uint32_t t1, uint32_t t2, uint32_t delayTime);
  _MIDI_SERIAL_PORT.begin(31250);
  if (UsbH.Init()) {
    while (1); //halt
  delay( 200 );
  UsbH.Task();
  uint32_t t1 = (uint32_t)micros();
  if ( Midi ) {
    MIDI_poll();
  //delay(1ms)
  doDelay(t1, (uint32_t)micros(), 1000);
// Poll USB MIDI Controler and send to serial MIDI
void MIDI_poll()
  uint8_t outBuf[ 3 ];
  uint8_t size;
  do {
    if ( (size = Midi.RecvData(outBuf)) > 0 ) {
      //MIDI Output
      _MIDI_SERIAL_PORT.write(outBuf, size);
  } while (size > 0);
// Delay time (max 16383 us)
  uint32_t t3;
    t3 = t2 - t1;
  if ( t3 < delayTime ) {
    delayMicroseconds(delayTime - t3);
Welcome to the world of system design! Have you considered implementing a watchdog timer? This could automatically reset the system if it locks up, as it seems to be doing based on what you’ve described.
