I have been working on a 8 relay solenoid driver that responds to midiusb messages. I am a newbie when it comes to some of the ins and outs of the programming. I have created a bodged together piece of code that manages to write the pins corresponding to the relays LOW when specific note on messages are received but I would also like the corresponding note off messages to write the pins HIGH. Can anyone help me with adding this functionality? Thanks!
Here is my sketch:
#include "MIDIUSB.h"
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
pinMode(2, OUTPUT); // set arduino pin to output mode
pinMode(3, OUTPUT); // set arduino pin to output mode
pinMode(4, OUTPUT); // set arduino pin to output mode
pinMode(5, OUTPUT); // set arduino pin to output mode
pinMode(6, OUTPUT); // set arduino pin to output mode
pinMode(7, OUTPUT); // set arduino pin to output mode
pinMode(8, OUTPUT); // set arduino pin to output mode
pinMode(9, OUTPUT); // set arduino pin to output mode
midiEventPacket_t rx = MidiUSB.read(); //listen for new MIDI messages
switch (rx.header) {
case 0x9: //Note On message
handleNoteOn(
rx.byte1 & 0xF, //channel
rx.byte2, //pitch
rx.byte3 //velocity
default:
void handleNoteOn(byte channel, byte pitch, byte velocity) {
switch (pitch) {
case 24: //kick = C1/24
digitalWrite(2, LOW);
case 25: //snare = C#1/25
digitalWrite(3, LOW);
case 26: //shake = D1/26
digitalWrite(4, LOW);
case 27: //cymbal = D#1/27
digitalWrite(5, LOW);
case 28: //? = D#1/27
digitalWrite(6, LOW);
case 29: //? = D#1/27
digitalWrite(7, LOW);
case 30: //? = D#1/27
digitalWrite(8, LOW);
case 31: //? = D#1/27
digitalWrite(9, LOW);
default:
