Mifare RFID-RC522
Hi... I'm newbie to arduino.
I've got a Mifare RFID-RC522 reader -writer. With some examples I found on the internet I managed to read the serial number of the cards, but ... Anybody can explain like a fool how I can write and read data on the cards? or Where I can get examples to do?
Thanks in advance.
Check this sketch: https://github.com/rena2019/myarduino/blob/master/RC522DumpMifare.ino
Thanks Rena... But this example is more complex for me. Do not exist any library for read-write data more simple?
Greetings.
┬┐Nobody? :~
Oso57: But this example is more complex for me. Do not exist any library for read-write data more simple?
Greetings.
to complex? The sketch is a one-file-solution: the lib-functions to talk to the board are included, that's why it looks so complex. You can replace the loop function with the following (untested) code:
void loop() { uchar buffer[MAX_LEN]; int block=0; //TODO: your block number if (selectCard(true) && MFRC522_Auth(PICC_AUTHENT1A, block, defaultKeyA, serNum) == MI_OK && MFRC522_Read(block, buffer) == MI_OK) { //TODO: block buffer contains the read data } }
if you want to read 1 block only
Hi, I've test the code and it's working. i can read all block of the Token.
So, now the question is : can you explain the use of the function Auth, we need to send defaultKeyA table, what is the content of the table ? what this table is it?
Thank you. Timiti29
Hello...
Thanks for your kindness
And to write? I can not find the way
Greetings.
Oso57: And to write? I can not find the way
Fill the buffer with the data you want to write and then use MFRC522_Write instead of MFRC522_Read from my sample code above (select,auth,write)
Thanks again for your kindness.
I am learning.
Greetings
