I have a code that runs on An Arduino UNO and I would like to transfer it on the Arduino YUN, the problem is that the code contains the SPI library (and the code has been gave me from a colleague and it's not my area of competence).
I have the chip AD9833 connected to the pins D10, D11, D13 and the potentiometer in A0 on the Arduino UNO.
How may I convert the code for works on the Arduino YUN?
AD9833 Waveform Module vwlowen.co.uk
#include <SPI.h>
const int SINE = 0x2000; // Define AD9833's waveform register value.
const int SQUARE = 0x2028; // When we update the frequency, we need to
const int TRIANGLE = 0x2002; // define the waveform when we end writing.
int wave = 0;
int waveType = TRIANGLE;
int wavePin = 7;
int freqoldmax;
int freqoldmin;
const float refFreq = 25000000.0; // On-board crystal reference frequency
const int FSYNC = 10; // Standard SPI pins for the AD9833 waveform generator.
const int CLK = 13; // CLK and DATA pins are shared with the TFT display.
const int DATA = 11;
unsigned long freq = 1000; // Set initial frequency.
int POT = A0;
// Can't set SPI MODE here because the display and the AD9833 use different MODES.
SPI.begin();
// Set the frequency and Sine Wave output
freq = analogRead(POT) * 10;
Serial.println(freq);
Serial.println(freqoldmin);
Serial.println(freqoldmax);
if (freq <= freqoldmin){
Serial.println("passaggio");
AD9833reset(); // Reset AD9833 module after power-up.
delay(50);
AD9833setFrequency(freq, SINE);
delay(10);
if (freq >= freqoldmax){
delay(50);
freqoldmin=freq-12;
freqoldmax=freq+12;
delay(50);
// AD9833 documentation advises a 'Reset' on first applying power.
void AD9833reset() {
WriteRegister(0x100); // Write '1' to AD9833 Control register bit D8.
delay(10);
// Set the frequency and waveform registers in the AD9833.
void AD9833setFrequency(long frequency, int Waveform) {
long FreqWord = (frequency * pow(2, 28)) / refFreq;
int MSB = (int)((FreqWord & 0xFFFC000) >> 14); //Only lower 14 bits are used for data
int LSB = (int)(FreqWord & 0x3FFF);
//Set control bits 15 ande 14 to 0 and 1, respectively, for frequency register 0
LSB |= 0x4000;
MSB |= 0x4000;
WriteRegister(0x2100);
WriteRegister(LSB); // Write lower 16 bits to AD9833 registers
WriteRegister(MSB); // Write upper 16 bits to AD9833 registers.
WriteRegister(0xC000); // Phase register
WriteRegister(Waveform); // Exit & Reset to SINE, SQUARE or TRIANGLE
void WriteRegister(int dat) {
// Display and AD9833 use different SPI MODES so it has to be set for the AD9833 here.
SPI.setDataMode(SPI_MODE2);
digitalWrite(FSYNC, LOW); // Set FSYNC low before writing to AD9833 registers
delayMicroseconds(10); // Give AD9833 time to get ready to receive data.
SPI.transfer(highByte(dat)); // Each AD9833 register is 32 bits wide and each 16
SPI.transfer(lowByte(dat)); // bits has to be transferred as 2 x 8-bit bytes.
digitalWrite(FSYNC, HIGH); //Write done. Set FSYNC high
If somebody has any idea how to solve this problem I will be very grateful
Thanks
Giulio
