Migrated from PC to Mac
Hey all
I recently changed to a Mac from PC and I am having trouble getting my sketches running.
for instance the following for a tilt compensated compass worked well before but I cannot make it work now
#include <Wire.h>
#include <MMA7660.h>
#include <HMC.h>
int a;
int var_compass;
int getcompasscourse(){
  int ax,ay,az,cx,cz,cy;
  MMA7660.getValues(&ax,&ay,&az);
  HMC.getValues(&cx,&cz,&cy);
  float xh,yh,ayf,axf;
  ayf=ax/57.0;//Convert to rad
  axf=ay/57.0;//Convert to rad
  xh=cx*cos(ayf)+cy*sin(ayf)*sin(axf)-cz*cos(axf)*sin(ayf);
  yh=cy*cos(axf)+cz*sin(axf);
  var_compass=atan2((double)yh,(double)xh) * (180 / PI) -90; // angle in degrees
  if (var_compass>0){var_compass=var_compass-360;}
  var_compass=360+var_compass;
  return (var_compass);
  MMA7660.init();
  int x,y,z;
  delay(100); // There will be new values every 100ms
  MMA7660.getValues(&x,&y,&z);
  Serial.print("x: ");
  Serial.print(x);
  Serial.print(" y: ");
  Serial.print(y);
  Serial.print(" z: ");
  Serial.println(z);
  HMC.getAngle(&a);
  Serial.println(a);
I believe it is something to do with the updates in the new Arduino version and I have read the release notes but being unfamiliar with Macs I am struggling.
I downloaded the Mac software which was a zip file and when the download was finished it was just an Arduino file which I clicked on and the Arduino environment opened.
I installed the FTI drivers correctly but the issue I am having is errors when verifying about the wire library.
I have no core library folder in my documents folder with Arduino.h or wire.h in it
I read in the release notes that you need to replace
#include <wProgram.h> with <Arduino.h> and that there is a bit of code you can add that includes Arduino.h when needed and uses wProgram.h when needed but I don know where to put it or where to find it.
I have no Arduino.h file on my Mac.
Can someone steer me in the right direction.
Once I have the .h files sorted then I can easily change the wording for Serial etc as per the release notes.
***Edit. I have now edited all the .h files in my libraries to include
#if defined(ARDUINO) && ARDUINO >= 100
#include “Arduino.h”
#else
#include “WProgram.h”
#endif
However I still get a WProgram.h no such file or folder error. I found the core libraries in the package and copied the libraries folder and pasted it into the Arduino folder but that didnt work either.
***Abort ***Abort ***Abort
I have solved it. Finally tracked down the culprit. I had to edit wire.send and wire.receive etc and edit all the WProgram references but I fixed them.
Thanks
Steve
