Hello everyone!
I successfully managed to control a cheap motor that came with nearly zero spec vip fast PWM signal. This motor is a replacement for the motor that drives the water turbine of my broken sous-vide-stick from Unhold.
As I found out the motor needs PWM frequencies above 21kHz and I found code online using timer 1 that did the job.
I implemented this code on my Leonardo with the help of this forum while waiting for the Nano to be shipped.
Then I uploaded the following code to the Nano V3 and nothing happened with the motor >:( .
Any suggestions what needs to be changed in the code when going from Leonardo to Nano?
Fast PWM Test
Demostrates the generation of high speed PWM
using timers 1
There are two pieces of code:
One for pins 91 using TIMER 1
with frequencies up to 62kHz
History:
12/12/2014 - Version 1.0
22/12/2014 - Adding a missing OCR4C value
Works with Leonardo
Fast PWM on pins 9, (TIMER 1)
Do not use analogWrite to pins 9, 10 or 11 if using
this functions as they use the same timer.
Those functions will probably conflict with the
servo library.
Uses 5 PWM frequencies between 61Hz and 62.5kHz
// Frequency modes for TIMER1
#define PWM62k 1 //62500 Hz
#define PWM8k 2 // 7812 Hz
#define PWM1k 3 // 976 Hz
#define PWM244 4 // 244 Hz
#define PWM61 5 // 61 Hz
// Direct PWM change variables
#define PWM9 OCR1A
// Configure the PWM clock
// The argument is one of the 5 previously defined modes
void pwm91011configure(int mode)
// TCCR1A configuration
// 00 : Channel A disabled D9
// 00 : Channel B disabled D10
// 00 : Channel C disabled D11
// 01 : Fast PWM 8 bit
TCCR1A=1;
// TCCR1B configuration
// Clock mode and Fast PWM 8 bit
TCCR1B=mode|0x08;
// TCCR1C configuration
TCCR1C=0;
// Set PWM to D9
// Argument is PWM between 0 and 255
void pwmSet9(int value)
OCR1A=value; // Set PWM value
DDRB|=1<<5; // Set Output Mode B5
TCCR1A|=0x80; // Activate channel
// Generates 4 PWM signals, two constant and two variable
// Configure Timer 1 (Pins 9)
// It will operate at 62kHz
// Valid options are:
// PWM62k, PWM8k, PWM1k, PWM244 and PWM61
pwm91011configure(PWM62k);
// Pins 9 will change value in the loop function
// We first configure them
// Prepare pin 9 to use PWM
// We need to call pwm91011configure
// For now, we set it at 0%
pwmSet9(0);
int value=255;
int steadyrpm=21; // =4900rpm
int steadytime=1200; // Divide by 10 to get seconds here 2 min
int lowtime=150; // Divide by 10 to get seconds here 15 sec
int counter=0;
int phase=1;
// Set PWM at pins 9
// Those fast macros require a previous configuration
// of the channels using the pwmSet9
// functions
// The functions pwmSet9 acan be used
// instead, but the PWM9 and PWM6 macros are faster
// to execute
PWM9=value;
switch(phase){
case 1:
// Increment PWM value and return from 255 to steadyrpm=21
value=(value-10)%256;
if (value<steadyrpm)
phase=5;
// Small 100ms delay
delay(100);
case 2:
value=(steadyrpm-15); // 5300 rmp = 21-15
counter=counter+1;
if (counter>lowtime)
phase=5;
counter=0;
delay(100);
default:
value=(steadyrpm);
counter=counter+1;
if (counter>steadytime)
phase=2;
counter=0;
delay(100);
You better ask the experts in the other forum for incompatibilities between Leonardo and Nano controllers. Without a detailed description it's hard to understand what your code is assumed to do.
Thanks for the answer! I was also struggling to find the right place to post this question.
The code is supposed to do PWM signals with high frequencies above 21kHz which seems not to be the native frequency for an Arduino. They’re different posts and approaches to that on the Internet and I was actually very happy to find something that I got to work without my detailed Arduino programming knowledge.
The best way to think about the Arduino Nano timers is to think about the timers in the underlying chip: the ATmega328. It has three timers:
Timer 0: 8-bit, PWM on chip pins 11 and 12
Timer 1: 16-bit, PWM on chip pins 15 and 16
Timer 2: 8-bit, PWM on chip pins 17 and 5
So I guess that timer 1 affects not pin 9 but 25 and 16 on the Nano? Or does that reference to the pins on the CHP and not to the pins in the code/board?
Timer 1 affects pins 15 and 16 of the ATmega328 chip which are wired to the pins D9 and D10.
The problem is the code in the routines pwm91011configure() and pwmSet9(). Direct register manipulations are processor specific and the values chosen here are not correct for the ATmega328.
Fortunately most configurations are identical for the two processors but you have to change this line (at least):
The PWM frequency is determined by the timer prescaler mode (coarse), ICR or OCRA (fine), and the duty cycle by OCRA or OCRB. The datasheet pin numbers refer to chip pins, not board pins.
With this tiny modification the code runs like a charm on my Nano.
As DrDiettrich didn't provide any finished code it would be nice for any user with a similar problem to post the complete final code that runs on your Nano.
It's quite unlikely that hardware (timer...) related code can be used by copy&paste in some other project - see this thread. That's why I think that it's better to teach people how to master the hardware instead of presenting just another specialized code project.
At least for me it worked with copying something, trying to understand it a little and modify it to my needs. As log as you use the same chip you can get pretty far using this approach. Of course you need somewhere some people that have the full picture.
Here is my complete code also now having a litte extra code to listen to an input value that is used as a switch to turn the motor on (0V=on 5V=off).
Fast PWM Test
using timers 1
History:
Works with Leonardo
servo library.
int inPin = 7; // PWM Signal from sous-vide-stick board to digital pin 7
#define PWM9 OCR1A
TCCR1A=1;
TCCR1B=mode|0x08;
TCCR1C=0;
// Set PWM to D9
//DDRB|=1<<5; // Set Output Mode B5 for Leonardo
DDRB|=1<<1; // Set Output Mode B5 for Nano
// Start of demostration code
pwmSet9(0);
pinMode(inPin, INPUT); // sets the digital pin 7 as input for the PWM Signal from the sous-vide-stick board
int value=255;
int lowtime=150; // Divide by 10 to get seconds here 15s
int counter=0;
int phase=1;
int switchon = 0; // variable to store the read value
// functions
// to execute
PWM9=value;
switchon = digitalRead(inPin); // read if water turbine shoud spin
if (switchon==LOW)
switch(phase){
case 1:
// Increment PWM value and return to 0 after 255
phase=5;
//value=RPM2PWM(3000);
//value=70;
// Small 10ms delay
delay(100);
case 2:
counter=counter+1;
phase=5;
counter=0;
delay(100);
default:
value=(steadyrpm);
counter=counter+1;
phase=2;
counter=0;
delay(100);
value=255;
phase=1;
