milis analog read error
Hello, i’m having a problem with this code. Actually i want to read an analogRead in 3 seconds with a photoresistor, but it didn’t work. I connected the photoresistor to A0 pin, also a led connected a led to simulate this code that blink every 3 sec. Please correct my code below if i missed something or wrong.
void setup
pinMode( LED, OUTPUT );
pinMode(A0, INPUT);
pinMode(12, OUTPUT);
boolean analogAboveThreshold(int pin, unsigned long millisec, int threshold)
unsigned long start = millis();
while (analogRead(pin) >= threshold); // blocking !!
unsigned long duration = millis() - start;
return ( abs(duration - millisec) <= 100 );
if (analogAboveThreshold(A0, 3000, 500) )
digitalWrite(13,HIGH);
delay(3000);
digitalWrite(13,LOW);// yes we have ~3 seconds high
digitalWrite(12,HIGH);
delay(3000);
digitalWrite(12,LOW);
anyway thank you
lets start simple
what do you want it to do?
you want it to read a photocell for 3 seconds. Or you don't want it to read the photocell for 3 seconds?
write a simple line by line list of what you want
example:
first 3 seconds do nothing read photocell to see if it light if it is light turn on led if it is dark turn off led repeat
I agree with @gpop1's suggestion to write out what you want clearly, line by line.
You may find something useful in planning and implementing a program which starts with a list of steps. Also look carefully at how it uses millis() to manage timing and does not use delay().
...R
@Ha-fiz: Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the “Code” icon above the posting area. It is the first icon, with the symbol: </>
How to use this forum
