I'm about a year into learning Arduino programming and am pretty chuffed I have got this far.....
I am developing a power feed system for my small milling machine. This is not CNC but a system that gives me three modes for manual milling only.
The system comprises of two DC motors and a dual H-Bridge driver controlling the X and Y axis only.
The three modes are......
Joystick Mode ( for fun really but it does help shunt the bed around very quickly )
Incremental Mode ( allows me to nudge the bed accurately onto a dial test indicator or position )
Power Feed Mode ( this allows me to cut continuously until commanded stop, limit switch or bad stuff )
I have been developing it for a while all test mounted on a piece of wood with some small test DC motors and have managed to debug a fair few problem/learning issues. For example stopping the motors from going full power momentarily on power up.......
In all honesty I have basically copied bits from other peoples code and have got away with not fully understanding it but somehow making it work.
The problem now is the system needs a feedback loop to maintain constant speed due to the fact that the load can vary when actually cutting metal. For example I have to wind up the PWM as the tool hits the metal and then back it off before it exits at the end of the cut otherwise she bursts out like a scalded cat. This is all pretty obvious now in hind sight.
I have added a 400 PPR encoder to each axis and have got the PID library in the code and it seems to behave to a point. I am again pretty chuffed to get this far......
I can't for the life of me get the encoder to read the right speed. This section of the code was stolen from the forum but I don't fully understand it. I have played blindly with the values but can't solve it.
I'm pretty sure there is plenty of scope for simplify this whole code over time as I learn more. I'm really looking forward to playing with the PIDs too as I have enjoyed setting them up on my Quadcopters.
I hope this makes some kind of sense and if you can help me get over this little hurdle that would be great...!
Thanks for looking at this.
Sorry if I'm approaching this wrong. I am a bit fresh.
I never doubted that your DC motor has enough power.
At 1650 RPM = 27.5 RPS and with 400 PPR then there will be 11000 pulses per second or one every 91 microsecs. That does not leave a lot of time for the Arduino to do other stuff.
Am I correct to assume that " geared down twice" means the motor is running at 3300 RPM or 55 RPS.
My guess is that something on the motor shaft that produces one or two pulses per rev of the motor would be quite sufficient for speed control. And it would greatly reduce the computation load on the Arduino.
And you did not say how far the tool advances for one turn of the motor.
You're going to have extreme difficulty getting a DC motor to increment with precision.
Even with some form of position sensor, the stopping time of the motor will depend upon drive voltage (PWM duty) (ie motor speed) and mechanical load so your control system would need to monitor electrical PWM duty (speed), electrical load (for mechanical load) and position. If the load is high the stopping time will be short and hence the position sensor input might relate closely to where you actually want to stop. With a light load the motor will tend to 'run on' and hence the position sensor input will have to give an 'early' command so the run on can be compensated for.
If you want consistent increments then you need an incrementing motor (stepper motor)
jackrae:
I may well be mistaken but I don't think the OP is concerned with precise positioning. The impression I have is that he just wants an automated system to save him the trouble of moving the tool-feed by twiddling the handle.
Feeds are pretty slow in a mill, this is a position control system, not a speed control system.
The target position changes with time, but that's immaterial, I think you need a position control loop,
driving a current control loop perhaps - this allows the current control loop to abort the feed operation
if the current exceeds a threshold, which will protect the leadscrew system from damage.
The position control loop can implement soft limits of course, which a speed control loop couldn't
Robin2:
...R
Apologies. I think I was just showing off about the power and just needed to tell someone.
I haven't had time to get out to the shed and fire my RPM gun around today. I think I need to do some more of this.
Put like that 400PPR sounds way too excessive for what I'm trying to do. I can see how this could jam up the Arduino. I was given one encoder so I blindly bought another matching as they were super cheap.
The pulleys are I think 14T to 60T twice. Sorry for the vagueness. I'm not even home yet tonight.....
Sorry for not answering your first Q. I'll get my clock out and get back to you feed/MotorRev
jackrae:
Hi there
This is not a precision system. R is correct. I don't want to have to stand there turning handles at home on this mill. I want to learn feedback, servo, PID loop gently.
The incremental mode of this system works really well as you can nudge onto a DTI quite aggressively then wind down the PWM to nothing as you reach your target visually. I actually like over the many CNC controls I'm very used to (Fanuc, Heidenhain, Siemens etc).
FYI I'm a 5 axis CNC programmer and machinist by trade mostly working on experimental turbine blades and blisks.
I have another mill that I will add CNC in time possibly 5 axis. I've no doubt I will create plenty of probs here. Rotary backlash is an itch I want to scratch soon......
MarkT:
Hi there
This is a pure PowerFeed system with nudge capabilities and a joystick for fun. Not a serious CNC with nano meters of accuracy. All I need/want is constant speed here.
Standard ACME threads and crappy limit switches off my 3d printer are working great. To be honest I want to strip the the lead screws and probably will. The mill is crud and good for not very much but learning. She might see ball screws one day but the ways need scraping way before I throw down any real money.
Suit yourself, it may not work very well though, snatching and jumping in speed with sudden load changes.
The main function of the control loop is to compensate for load changes (I'm assuming large forces in
either direction can happen). Position control is eminently suited to do this, simple speed control is not.
MarkT:
You maybe be right about the jumping and snatching. Milling is an extremely dynamic process.
I'm very curios to find out what I can achieve personally and the limits of what the loop can give me in the setup.
If I pull the trigger on ball screws I will most likely go down the positional control as you advise.
I strongly recommend thinking about a position feedback loop using a PID. The control input can
be made to continually change for low speed control with strong holding power.
Robin2:
...R
The bed advances by 175 micron/rev of the motor.
I have got some optical switches to try out. How many pulses would you recommend for measuring 1650 rpm?
barneycoles:
That really depends on how quickly the motor can accelerate or decelerate when the load changes. For example if it takes a few revolutions to slow down (because of momentum in the system) then one pulse per revolution should be sufficient.
On the other hand if it can go from regular speed to a complete stop in a quarter revolution you will need maybe 16 or 32 pulses per revolution (maybe more) so that the Arduino can adjust the motor power quickly enough to prevent a stall.
Of course the other side of this is how quickly the motor can respond to more or less power. If the load can stop the motor in a quarter turn but the motor takes the time for a half-turn to respond then it probably does not matter how many pulses you have, it won't work.
As I think about this the attractions of a stepper motor shine out very brightly
Robin2:
...R
Great stuff....!
Thanks R.
Time to fire up the printer and make some indexing discs.
I think a higher number of pulses would be best. I can see very little coasting from full chat to stop. I have sprung mounted the limit switches in anticipation of this but it seems this was not necessary so far.
In the name of science and learning I'm stubbornly not throwing in the towel to the stepper yet but you are right.
The whole thing is screaming STEPPER MOTOR.......job done.
Robin2:
...R
So I have the optical switch mounted and a 25 PPR disc as per stolen RPM code and it all seems to be picking up nicely.
I'm still getting about 40% error compared with the indicated RPM from my RPM gun. I'm pretty confident that the RPM gun is accurate as the serial monitor is indicating over 4000 RPM at full chat. I think if my belts were going over 4 grand I'd know it and would probably stand back a bit further.
Robin2:
The code in this link is simpler. It simply measures the time between pulses.
...R
Ok. Looks like I'm going to have to take step back and get reliable RPM.
I'm building a new test rig to code this in in my warm home office. I don't fully understand some of it though but I will plod away at it so thanks for that.
Any ideas as to why my current arrangement and code is so far out?
I have now tried a 25 PPR disc, a 1 PPR disc and a 2 PPR. Nothing I do gives me anywhere near the RPM indicated by the RPM gun.
1600 RPM is indicating over 4000 in the serial monitor. 60% error.
I notice you are using micros not millis. Am I trying to get the Arduino to do too much in not enough time? Surely 1 PPR at 1600 RPM and PID calc is manageable
Should I perhaps detachInterrupt during calculation? I noticed this in someone else's RPM code?
barneycoles:
My motor control works fine at 16,000 RPM with a PID update once per revolution. And it receives wireless data to tell it the chosen speed. However I think my PID calculations are significantly faster than the Arduino PID library as I don't use floating point maths. Otherwise my calculations are the same.
