I have this school project, it's a solar panel tracker and Voltage tester through bluetooth at the same time.
I'm controlling the solar panel tracker with a simple Servo at pin11 with the comparator sensors (two LDRs) at A0 and A1. Next is the Bluetooth, I'm using a potentiometer as a representation for the varying voltage of a Solar panel. It is connected at A7. You can visually see the output voltage with an App that I made which is connected through a bluetooth shield to my arduino. My main problem is how I simultaneously run the both of them. The two codes work independently but when I integrated it, it didn't work. The reading that is shown on my phone is always delayed while the program waited for the servo to align with the sensors. Also, I've tried using millis() but can't seem to make it work.
Thank you for your help in advance!
#include <Servo.h>
byte volt = A7;
Servo tracker; // create servo object to control a servo
int eastLDRPin = A0; //Assign analogue pins
int westLDRPin = A2;
int eastLDR = 0; //Create variables for the east and west sensor values
int westLDR = 0;
int error = 0;
int calibration = 10; //Calibration offset to set error to zero when both sensors receive an equal amount of light
int trackerPos = 90;
int Bsend = 10;//Create a variable to store the servo position
const int Binterval = 200; //Bluetooth interval
unsigned long previousMillis1=0;
unsigned long previousMillis2=0;
unsigned long currentMillis;
unsigned long currentMillis2;
const int Sinterval = 100; //Servo interval
unsigned long previousMillis3=0;
unsigned long previousMillis4=0;
unsigned long currentMillis3;
unsigned long currentMillis4;
unsigned long Bint=0;
unsigned long Sint=0;
pinMode(volt,INPUT);
tracker.attach(11); // attaches the servo on pin 11 to the servo object
if (millis() >= Binterval + Bint){
Bint = millis();
byte lvl = map(analogRead(volt),164,1023,0,20);;
Serial.write(lvl);
if (millis() >= Sinterval + Sint) {
Sint = millis();
eastLDR = calibration + analogRead(eastLDRPin); //Read the value of each of the east and west sensors
westLDR = analogRead(westLDRPin);
if(eastLDR<100 && westLDR<100) //Check if both sensors detect very little light, night time
while(trackerPos<=160) //Move the tracker all the way back to face east for sunrise
trackerPos++;
tracker.write(trackerPos);
error = eastLDR - westLDR; //Determine the difference between the two sensors.
if(error>15) //If the error is positive and greater than 15 then move the tracker in the east direction
if(trackerPos<=160) //Check that the tracker is not at the end of its limit in the east direction
trackerPos++;
tracker.write(trackerPos); //Move the tracker to the east
if(error<-15) //If the error is negative and less than -15 then move the tracker in the west direction
if(trackerPos>10) //Check that the tracker is not at the end of its limit in the west direction
trackerPos--;
tracker.write(trackerPos); //Move the tracker to the west
if (15>error>-15){
You should NOT be adding times. You SHOULD be using meaningful names. What the heck is a Bint?
You;; should;;;; pay; attention;;;;;; to where;; semicolons;;;;;; are needed, and;;; how many.
trackerPos++;
Why do you need a while loop? Just set trackerPos to 160, and write that one value to the servo. That while loop will complete long before the servo actually gets to 160.
if (15>error>-15){
That is NOT how to test that a value is in a range. There are NO shortcuts.
#include <Servo.h>
byte volt = A7;
int westLDR = 0;
int error = 0;
int trackerPos = 90; //Create a variable to store the servo position
trackerPos++;
delay(100);
trackerPos++;
delay(100);
trackerPos--;
delay(100);
if (15>error>-15){
delay(100);
Since you are looping through code, very fast, you want to avoid all "blocking" code. If you wait for a mechanical part, like a servo to move, You are not doing a lot of things you could be doing in the same time.
PaulS:
How do I set the trackerPos?
I'm sorry, I'm a complete newbie with arduino for servos
Tried the revision on my project but the problem is still reoccurring.
The servo first adjusts while the arduino sends a good signal to the bluetooth shield, yet whenever I try to adjust the potentiometer it takes a long time before there is a change on the graph on my phone. Especially when I try to do it simultaneously. I try to change the direction of light (so that the servo will respond and readjust the tracker) and change the position of the potentiometer
#include <Servo.h>
byte volt = A7;
int westLDR = 0;
int error = 0;
if (millis() - Bint >= Binterval){
Bint = millis();
Serial.write(lvl);
if (millis() -Sint >= Sinterval) {
Sint = millis();
if(trackerPos<=160) //Move the tracker all the way back to face east for sunrise
trackerPos++;
trackerPos++;
trackerPos--;
if (15>error && error>-15){
If you used a meaningful name, the comment would be unnecessary.
Getyourspacekeyfixed.
That comment is stupid. There is NO interval associated with bluetooth. YOU might wish to only send data after some interval, but that send interval is NOT a bluetooth interval.
Sending data after some interval is NOT the correct way to do it. Send the data immediately, when it changes. Of course, that means you need to keep track of what you sent last time, so you know when a change occurs.
Again, that is NOT a servo interval. Servos don't have intervals.
How many copies of now do you need?
More stupid names. These are supposed to hold the time that an event occurred. Name the variable for the event, not the unit of measure of the data in the variable.
I understand that some of my comments and the use of name on my code do not fit typical norms.
I'm sorry, but what I really need now is how I could integrate both of my codes so that I could simultaneously change the position of the servo while my arduino is sending data to my phone on what is the current voltage of the potentiometer. I believe I could use millis() for this but I've tried I don't know why it won't work. I've tried it on both separate codes but whenever I try to integrate it, it just doesn't work. It always waits for another to finish what it's doing before it send the next data to the bluetooth
Of course it does, because you can NOT do two things at the same time. You MUST stop writing blocking code, or ANY code that loops. The loop() function should do all the looping required.
You do not need to apologize for using stupid names. Just change them.
I think that when you do, you'll understand exactly why your code doesn't work the way you want.
You'll see that you are deliberately constraining the application to send data on a fixed (but possibly incorrect, because of the meaningless names) schedule, which is NOT what you want to do.
You want to send new data when the new data doesn't match the old data, regardless of what time it is when the data changes.
electronicskid:
It looks to me like the program you posted in Reply #10 should do that. But perhaps I am misunderstanding the rather cryptic variable names. I am assuming the the first piece of code in loop() (this bit)
Hey guys! I tried to rename some of the code and de-clutter some of the comments. Please take time to read my code. Thank you
#include <Servo.h>
byte volt = A7;
int westLDR = 0;
int error = 0;
int Bsend = 10; //Create a variable to store the servo position
unsigned long previousMillis;
unsigned long previousMillis2;
if (millis() - currentMillis >= Binterval){
previousMillis = millis();
byte lvl = map(analogRead(volt),164,1023,0,20); //Maps the Values of the voltages sensed at A7
Serial.write(lvl); //Sends the Data to the Android
if (millis() - currentMillis2 >= Sinterval) {
previousMillis2 = millis();
trackerPos++;
trackerPos++;
trackerPos--;
if (15>error && error>-15){ //When the sensors read that it is equal or withing specified range, it holds the current postion of the servo
electronicskid:
That program is not complete.
And it looks like you have not used the AutoFormat tool to indent it consistently. Doing that make it much easier to identify the different logical blocks.
As far as naming variables is concerned, I see this
You didn't try hard enough. These 4 lines still have stupid names.
Well, that's useful... NOT!
What does the code actually do now, and how does that differ from what you want?
