The proper way would be a state machine coded up with the behaviour and no calls to delay() nor
any busy-waiting such as your while loops.
The correct way to test for a time interval is this:
while(millis() - currentTime < interval){
and not as you used:
while(millis() < currentTime + interval){
Otherwise your code will misbehave when millis() wraps round. Always subtract two timestamps and
compare the result. The result of a subtraction is valid even when the counter wraps round.
You didn't post all your code. You could have replaced all that faulty millis() code with a simple delay(), but neither way will work for the reason stated above.
Look at the tutorials on the guide to posting on the top 3 stickies in this section. There are a few there called “doing Multiple things at the same time” etc. They will explain the use of millis correctly.
A while loop is blocking code. Like delay your code is stuck for an ‘eternity’ in uC time rather than looping every bit of a microsecond. Avoid all blocking code if you can.
* Created by ArduinoGetStarted.com
* This example code is in the public domain
* Tutorial page: https://arduinogetstarted.com/tutorials/arduino-motion-sensor
const int PIN_TO_SENSOR = 2; // the pin that OUTPUT pin of sensor is connected to
int pinStateCurrent = LOW; // current state of pin
int pinStatePrevious = LOW; // previous state of pin
const unsigned long DELAY_TIME_MS = 30000; // 30000 miliseconds ~ 30 seconds
bool delayEnabled = false;
unsigned long delayStartTime;
Serial.begin(9600); // initialize serial
pinMode(PIN_TO_SENSOR, INPUT); // set arduino pin to input mode to read value from OUTPUT pin of sensor
pinStatePrevious = pinStateCurrent; // store state
pinStateCurrent = digitalRead(PIN_TO_SENSOR); // read new state
if (pinStatePrevious == LOW && pinStateCurrent == HIGH) { // pin state change: LOW -> HIGH
Serial.println("Motion detected!");
Serial.println("Turning on / activating");
delayEnabled = false; // disable delay
// TODO: turn on alarm, light or activate a device ... here
if (pinStatePrevious == HIGH && pinStateCurrent == LOW) { // pin state change: HIGH -> LOW
Serial.println("Motion stopped!");
delayEnabled = true; // enable delay
delayStartTime = millis(); // set start time
if (delayEnabled == true && (millis() - delayStartTime) >= DELAY_TIME_MS) {
Serial.println("Turning off / deactivating");
// TODO: turn off alarm, light or deactivate a device ... here
