Millis assignment to variable not working
Hello all,
I am having trouble assigning a millis() result to a variable. The value of the variable is always zero after the statement var = millis(); The variable is declared as an unsigned long. I have the code using 2 ide's on separate machines with separate Arduino mega's and get the same result.
Following is the test code used and the serial monitor result.
// Global Variables
unsigned long set_time = 0;
unsigned long duration = 20000;
unsigned long calculated_result = 0;
  set_time = millis();
  Serial.print("The value of duration is ");
  Serial.println(duration);
  Serial.print("The value of set time is ");
  Serial.println(set_time);
  Serial.print("The current value of millis is ");
  Serial.println(millis());
  calculated_result = millis() - set_time;
  Serial.print("The value of calculated result is ");
  Serial.println(calculated_result);
Serial Monitor Result
The value of duration is 20000
The value of set time is 0
The current value of millis is 6038
The value of calculated result is 6038
The current value of millis is 7044
The value of calculated result is 7045
The current value of millis is 8050
The value of calculated result is 8050
Any help with why set_time is always 0 is most welcome.
You only assign to set_time within setup() so why do you think it will change? If you put a delay(1000) inside setup() at the very beginning, then set_time would always be 1000 (or close to it)
Thanks. Clearly not a logical thinking day for me.
