Hey everyone,
I am developing a payment system using RFID cards, and I want to use multiple RFID-RC522 readers at once so that they can read cards (almost) simultaneously.
To do this, I used the millis() function, but for some reason, it causes my whole program to stop and restart. The rest of the code works, so I don't know what I am doing wrong.
Below you can see a snippet of the code (the millis() function is right at the bottom).
Thank you in advance :).
#include <Wire.h>
#include <SPI.h>
#include <MFRC522.h>
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
float nums[5] ={};
byte rowPins[ROWS] = {8, 7, 6, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {4, 3, A0, A1}; //connect to the column pinouts of the keypad
int decimal =0;
LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 16, 2);
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
byte ledPin = 13;
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
float price = 0;
char MoneyLeft = 10;
MFRC522 mfrc522(SS_PIN, RST_PIN);
String value = "A9 A4 DE 8B";// Create MFRC522 instance
float cost = 0;
int c = 0;
boolean add =false;
int buzzPin = 2;
int buzztime = 500;
int t= 0;
float nrofElements;
float addition = 0;
const int buzzer =2;
boolean entered[6] = {};
String thirdscan;
String lastscan;
String currentScan="";
bool lunchTime=false;
int repeat =1;
bool newItem;
int firstid=0;
int actualfirstid;
int secondid=0;
int thirdid=0;
bool newline=false;
int indexForLastNum;
int totalItems;
unsigned long previousTime;
unsigned long currentTime;
String serialnumbers[] = {"A9 A4 DE 8B", "0A FA 82 16"}; //accounts
String names[] = {"Alex", "Marta"};
float account[] = {10, 20};
bool schoolLunch[] = {true, false};
int snackCount[]= {0,0,0,0,0,0,0,0,0,0,0,0};
String snackName[]= {"Coffee", "Croissant", "A. Juice", "Cookie", "Brezel", "Cherry Pastry", "Pingui", "Water", "C. Croissant", "Laugen", "Cheese Brzl", "Panini"};
float snackPrice[]={1.50, 1.30, 1.70, 1.5, 0.7, 1.6, 0.8, 1.2, 1.70,0.8,1.4,2.4,};
bool foodType[]= {false, true, false, true, true};
int drinkCount=0;
int foodCount=0;
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin();
lcd.init();
lcd.backlight();// Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522
mfrc522.PCD_DumpVersionToSerial(); // Show details of PCD - MFRC522 Card Reader details
Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
pinMode(buzzer, OUTPUT);
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
lcd.setCursor(0,0);
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
content.toUpperCase();
for (c = 0; c <= 1; c++){
if (content.substring(1) == serialnumbers[c]) //change here the UID of the card/cards that you want to give access
tone(buzzer, 1600);
delay(100);// ...for 0.1 sec
noTone(buzzer);
lcd.clear();
if (lunchTime){
Lunch(c, content.substring(1), thirdscan);
else{
Snack(content.substring(1), c, lastscan);
lastscan = content.substring(1);
currentScan ="";
void Lunch(int i, String currentScan, String beforelastScan){
lcd.clear();
lcd.setCursor(0,0);
currentTime=millis();
if (currentTime-previousTime >= 1500){
if (currentScan=="A9 A4 DE 8B"){
lcd.print("Snack Time");
lunchTime=false;
else{
if (schoolLunch[i] == false){
lcd.print("Home lunch");
else{
lcd.print("School lunch :)");
previousTime=currentTime;
