millis (different intervals) in a switch state
Below is the complete sketch I'm using. It works fine....the top half (JOYSTICK CONTROL) works as needed with a joystick to control horizontal and vertical. Another button turns on the circle motor.
The 2nd (else) random section (RANDOM CONTROL) is where I need help. I have used the millis rather than the delay, but I'd like a different interval for each motor. I don't know how to incorporate separate intervals with millis in a switch case.
I'd like something a beginner can grasp that is more basic Arduino coding. :slight_smile:
Thanks for your help.
steve
/*vericalBot 3 motors 2 with limit switches. Vertical, Horizontal and Circles.
 by steve craig for Steve's Machine Empire. 2015.
//VERTICAL MOTOR
const int switchPin = 7;    // switch input
const int switch2Pin = 8;    // switch input
const int motor1Pin = 2;    // H-bridge WHITE
const int motor2Pin = 4;    // H-bridge GRAY
const int enablePin = 3;    // H-bridge BLACK
int potPin = A0;
int motorSpeed = 0;
//HORIZONTAL
const int switchPinB = 5;    // switch input
const int switch2PinB = 6;    // switch input
const int motor1PinB = 12;    // H-bridge ORANGE
const int motor2PinB = 13;    // H-bridge RED
const int enablePinB = 11;    // H-bridge BROWN
int potPinB = A1;
int motorSpeedB = 0;
//CIRCLES
const int switchPinC = 10;    // switch input
const int motor1PinC = 18;    // H-bridge YELLOW
const int motor2PinC = 19;    // H-bridge GREEN
const int enablePinC = 9;    // H-bridge BLUE
int potPinC = A2;
int motorSpeedC = 0;
const int randomSwitch = 17;
int motorState = LOW;
const unsigned long     interval    = 250;
long previousMillis = 0;
  // VERTICAL
  pinMode(switchPin, INPUT);
  pinMode(switch2Pin, INPUT);
//HORIZONTAL
  pinMode(switchPinB, INPUT);
  pinMode(switch2PinB, INPUT);
//CIRCLES
  pinMode(switchPinC, INPUT);
  pinMode(randomSwitch, INPUT);
  // set all the other pins you're using as outputs:
  pinMode(motor1Pin, OUTPUT);
  pinMode(motor2Pin, OUTPUT);
  pinMode(enablePin, OUTPUT);
  pinMode(motor1PinB, OUTPUT);
  pinMode(motor2PinB, OUTPUT);
  pinMode(enablePinB, OUTPUT);
  pinMode(motor1PinC, OUTPUT);
  pinMode(motor2PinC, OUTPUT);
  pinMode(enablePinC, OUTPUT);
  // set enablePin high so that motorS can turn on:
  digitalWrite(enablePin, HIGH);
  digitalWrite(enablePinB, HIGH);
  digitalWrite(enablePinC, HIGH);
//JOYSTICK CONTROL OF VERT AND HORIZ. BUTTON ON-OFF FOR CIRCLES.
  if (digitalRead(randomSwitch) == HIGH) {
    if (digitalRead(switchPin) == HIGH) {
      digitalWrite(motor1Pin, LOW);   // set leg 1 of the H-bridge low
      digitalWrite(motor2Pin, HIGH);  // set leg 2 of the H-bridge high
      motorSpeed = analogRead(potPin) / 4;
      analogWrite(enablePin, motorSpeed);
      delay (10);
    // if the switch is high, motor will turn on one direction:
    else if (digitalRead(switch2Pin) == HIGH) {
      digitalWrite(motor1Pin, HIGH);   // set leg 1 of the H-bridge low
      digitalWrite(motor2Pin, LOW);  // set leg 2 of the H-bridge high
      delay (10);
    // if the switch is low, motor will turn in the other direction:
    else {
      digitalWrite(motor1Pin, LOW);  // set leg 1 of the H-bridge high
      digitalWrite(motor2Pin, LOW);   // set leg 2 of the H-bridge low
      delay (10);
    if (digitalRead(switchPinB) == HIGH) {
      digitalWrite(motor1PinB, LOW);   // set leg 1 of the H-bridge low
      digitalWrite(motor2PinB, HIGH);  // set leg 2 of the H-bridge high
      motorSpeedB      = analogRead(potPinB) / 4;
      analogWrite(enablePinB, motorSpeedB);
      delay (10);
    else if (digitalRead(switch2PinB) == HIGH) {
      digitalWrite(motor1PinB, HIGH);   // set leg 1 of the H-bridge low
      digitalWrite(motor2PinB, LOW);  // set leg 2 of the H-bridge high
      delay (10);
    else {
      digitalWrite(motor1PinB, LOW);  // set leg 1 of the H-bridge high
      digitalWrite(motor2PinB, LOW);   // set leg 2 of the H-bridge low
      delay (10);
    if (digitalRead(switchPinC) == HIGH) {
      digitalWrite(motor1PinC, LOW);   // set leg 1 of the H-bridge low
      digitalWrite(motor2PinC, HIGH);  // set leg 2 of the H-bridge high
      motorSpeedC      = analogRead(potPinC) / 4;
      analogWrite(enablePinC, motorSpeedC);
      delay (10);
    else {
      digitalWrite(motor1PinC, LOW);  // set leg 1 of the H-bridge high
      digitalWrite(motor2PinC, LOW);   // set leg 2 of the H-bridge low
      delay (10);
//RANDOM CONTROL.
  else {
    unsigned long           currentMillis   = millis();
    if ( (currentMillis - previousMillis) > interval)
      previousMillis  = currentMillis;
      motorSpeedC      = analogRead(potPinB) / 4;
      int move        = random(0, 9);
      switch (move) {
      case 0:
        digitalWrite(motor1Pin, motorState);
        digitalWrite(motor2Pin, !motorState);
      case 1:
        digitalWrite(motor1Pin, !motorState);
        digitalWrite(motor2Pin, motorState);
      case 2:
      case 3:
        digitalWrite(motor1PinB, motorState);
        digitalWrite(motor2PinB, !motorState);
      case 4:
        digitalWrite(motor1PinB, !motorState);
        digitalWrite(motor2PinB, motorState);
      case 5:
      case 6:
        digitalWrite(motor1PinC, motorState);
        digitalWrite(motor2PinC, !motorState);
      case 7:
        digitalWrite(motor1PinC, !motorState);
        digitalWrite(motor2PinC, motorState);
      case 8:
stevex:
Then you need a separate set of time variables for each motor. Something like this for the second motor:
    unsigned long  currentMillis2 = millis();
    if ( (currentMillis2 - previousMillis2) > interval2)
      previousMillis2  = currentMillis2;
if you are randomly moving it then maybe you could randomly change interval at the same time so it will move randomly for a random period of time
previousMillis must be "unsigned long" as well.
Yes, Henry_Best, but if I have 9 cases, 3 motors in each direction plus stop, where do I put the
"unsigned long currentMillis2 = millis();
? In other words, how does case 3,4,5 know it belongs to motor 2 and interval2?
stevex:
where do I put the
Use arrays
const byte numMotors = 3;
unsigned long prevMillis[numMotors]
unsigned long interval[numMotors]
then you can use a FOR loop
for (byte n = 0; n < numMotors; n ++) {
   if (currentMillis - prevMillis[n] >= interval[n]) {
      // whatever
You could be even more sophisticated and use a struct to hold the data for each motor and then create an array of structs. But I will leave you to research that yourself.
…R
Robin2:
…R
yes! like this example
not sure if something as simple as this would work
//VERTICAL MOTOR
int potPin = A0;
int motorSpeed = 0;
//HORIZONTAL
int potPinB = A1;
int move = 0;
int onetime = 0;
//CIRCLES
int potPinC = A2;
unsigned long previousMillis = 0;
  // VERTICAL
  //HORIZONTAL
  //CIRCLES
      delay (10);
      delay (10);
    else {
      delay (10);
      delay (10);
      delay (10);
    else {
      delay (10);
      delay (10);
    else {
      delay (10);
  //RANDOM CONTROL.
  else {
    if (onetime == 0) {
      switch (move) {
        case 0:
          interval = 1000;
        case 1:
          interval = 2000;
        case 2:
          interval = 3000;
        case 3:
          interval = 1500;
        case 4:
          interval = 1000;
        case 5:
          interval = 2500;
        case 6:
          interval = 3500;
        case 7:
          interval = 100;
        case 8:
          interval = 10000;
      onetime = 1;
      onetime = 0;
      switch (move) {
        case 0:
        case 1:
        case 2:
        case 3:
        case 4:
        case 5:
        case 6:
        case 7:
        case 8:
It doesn't appear to work...changes I make to intervals and the motors don't seem to be following that...
thanks, tho...
struct is a bit beyond me...I think I'm about 30 tutorials behind on that...
stevex:
Then use arrays and learn about structs later.
...R
stevex:
thanks, tho...
strange I added serial prints to see what I had done wrong and it seems to work correctly. I did notice that its not that random. You may want to use randomseed on a spare analog pin.
think I spotted the error now. I had to add a else to the millis compare as you want to use it until the timer is done
if you get a chance test this sketch using serial print.
//VERTICAL MOTOR
int potPin = A0;
int motorSpeed = 0;
//HORIZONTAL
int potPinB = A1;
int move = 0;
int onetime = 0;
//CIRCLES
int potPinC = A2;
  // VERTICAL
  //HORIZONTAL
  //CIRCLES
  randomSeed (analogRead (3));
      delay (10);
      delay (10);
    else {
      delay (10);
      delay (10);
      delay (10);
    else {
      delay (10);
      delay (10);
    else {
      delay (10);
  //RANDOM CONTROL.
  else {
    if (onetime == 0) {
      Serial.print("random results ");
      Serial.println(move);
      switch (move) {
        case 0:
          interval = 1000;
        case 1:
          interval = 2000;
        case 2:
          interval = 3000;
        case 3:
          interval = 1500;
        case 4:
          interval = 1000;
        case 5:
          interval = 2500;
        case 6:
          interval = 3500;
        case 7:
          interval = 100;
        case 8:
          interval = 10000;
      Serial.print("interval ");
      Serial.println (interval);
      onetime = 1;
      Serial.println("time done");
      onetime = 0;
    else {
      switch (move) {
        case 0:
        case 1:
        case 2:
        case 3:
        case 4:
        case 5:
        case 6:
        case 7:
          Serial.println("motor doing its thing 100ms");
        case 8:
I think it would be better if you also added code so it can not repeat the same random number.
