Millis() fade in--hold--fade out over hours; LEDs
Hi! From looking at the other threads on here, I attempted to code a daylight/noon/night cycle for my LED project.
I ran it overnight to see if it actually works…and it in fact doesn’t. According to the serial.Print function, I can see it actually is counting up when connected to the computer.
 Nano_R With Fading
 The circuit:
 * Two strings of LEDS with separate drivers attached to digital pin 9 and pin 10.
 * Fade in over 2 hours, hold max brightness for 3 hours, fade out over 3 hours.
int whiPin = 9;
int bluPin = 10;
long intervalmorn = 28235;   // 2 hours--frequency of changes, sunrise
long intervalnoon = 42352; // 3 hours--frequency of changes, max brightness
long intervalnite = 42352; // 3 hours--frequency of changes, sunset
  int fadeValuerise = 0;
  int fadeValueset = 255;
  int holdValuenoon = 0;
void setup()  {
void loop()  {
  // fade in from min to max in increments of 28235 points:
  while(fadeValuerise < 255) {
    // sets the value (range from 0 to 255):
    analogWrite(whiPin, fadeValuerise);
    analogWrite(bluPin, fadeValuerise);
      if(currentMillis = fadeValuerise*intervalmorn) {
        fadeValuerise ++;
long oldmillis1 = 7199925; //millis counter continuation from above
  while(holdValuenoon < 255) {
    analogWrite(whiPin, 245);
    analogWrite(bluPin, 255);
      if(currentMillis = oldmillis1 + (holdValuenoon*intervalnoon)) {
        holdValuenoon ++;
long oldmillis2 = 17999685; ////millis counter continuation from above
  // fade out from max to min in increments of 42352 points:
  while(fadeValueset > 0) {
    // sets the value (range from 255 to 0):
    analogWrite(whiPin, fadeValueset);
    analogWrite(bluPin, fadeValueset);
    if(currentMillis = oldmillis2 + (fadeValueset*intervalnite)) {
      fadeValueset --;
I hope someone can help me out here! Really bummed out since it all made sense to me in my head. :frowning:
Thanks in advance!
Jonathan
if(currentMillis [glow]=[/glow] fadeValuerise*intervalmorn)
if(currentMillis [glow]=[/glow] oldmillis2 + (fadeValueset*intervalnite))
http://arduino.cc/en/Reference/If
Can you explain some of the constants?
Thanks for the crazy fast reply!
I thought that to make it easier, I'd use a rounded number (in milliseconds) equivalent for 2 hours, 3 hours, and 3 hours. These rounded numbers are the first three longs in the beginning of the code.
If these numbers, multiplied by the place in the while loop (0-255), can be compared to the currentMillis counter, then we can use it to trigger when to move the loop from 0 to 1, and from 1-2, etc. This should increase the loop linearly over a course of roughly 2 hours, or so i think..?
The others (hold 3 hours, fade over 3 hours) were made with the same thought process.
Summary: Compare the currentMIllis counter to the multiplied out value (2 hours divided by 255 and current pwm value [0-255]). If comparison = true, increase loop counter by 1.
Maybe helps?
I thought that to make it easier, I’d use a rounded number (in milliseconds) equivalent for 2 hours, 3 hours, and 3 hours
Nope, still not seeing it.
28235 / 1000 (milliseconds) = 2823.5 seconds = 47 minutes 3.5 seconds. Quite a way short of an hour.
Make it easy for yourself, ues the compiler and the preprocessor,
const unsigned long MILLIS_PER_SECOND = 1000UL;
const unsigned long MILLIS_PER_MINUTE = 60UL * MILLIS_PER_SECOND;
const unsigned long MILLIS_PER_HOUR = 60UL * MILLIS_PER_MINUTE;
or something similar.
What I meant with the 28235 is 2 hours convert to--> milliseconds = 7,200,000 milliseconds, which is then divided by 255 "steps" for 28235.
I kinda understand what you're getting at with the MILLIS_PER_SECOND, etc. I'll update my code now to make it less stupid. ;)
Would this work out for what we’re trying to do?
 Nano_R With Fading
 The circuit:
int whiPin = 9;
int bluPin = 10;
long intervalmorn = 2*MILLIS_PER_HOUR;   // 2 hours--frequency of changes, sunrise
long intervalnoon = 3*MILLIS_PER_HOUR; // 3 hours--frequency of changes, max brightness
long intervalnite = 3*MILLIS_PER_HOUR; // 3 hours--frequency of changes, sunset
void setup()  {
void loop()  {
      if(currentMillis = (fadeValuerise*2*MILLIS_PER_HOUR)/intervalmorn) {
        fadeValuerise ++;
const long oldmillis1 = millis(); //millis counter continuation from above
    analogWrite(whiPin, 230);
    analogWrite(bluPin, 245);
      if(currentMillis = oldmillis1 + ((holdValuenoon*3*MILLIS_PER_HOUR)/intervalnoon)) {
        holdValuenoon ++;
long oldmillis2 = millis() ///millis counter point after completing second loop above
    if(currentMillis = oldmillis2 + ((fadeValueset*3*MILLIS_PER_HOUR)/intervalnite)) {
      fadeValueset --;
Fewer giant numbers–more easily accessed hopefully…
Need help...I'm getting 0V out of the PWM pins using this code. Anyone?
How are you measuring that 0V? A PWM pin is turned on and off for various (short) durations, such that the ON time is the specified ratio of total time. Many multi-meters do not measure voltage well on PWM pins. LEDs connected to PWM pins appear to work correctly because the brain can not process the on/off cycling fast enough, so the LED appears to be on all the time.
You still have some coding issues that you have not addressed.
This statement will compute a value, and assign it to currrentMillis. This is probably not what you want to be doing. You want to compare the value currently in currentMillis to the computed value (using ==).
Thanks for the help paul. I changed the conditionals to == per your suggestions. I didn’t measure the 0v, I just guessed that was the case because the LED’s stayed completely unlit for hours.
After adding the ==, it puts out light, but heavily dimmed. Stays constant like this otherwise.
There’s gotta be something wrong with this structure huh…
      if (currentMillis == ((fadeValuerise*2*MILLIS_PER_HOUR)/intervalmorn)) {
        fadeValuerise ++;
Almost there…! i’m hopeful :slight_smile:
Since intervalmorn is set to 2*MILLIS_PER_HOUR, the if test boils down to:
if (currentMillis == fadeValuerise) {
        fadeValuerise ++;
But, currentMillis is the number of milliseconds since the Arduino was restarted. Expecting that value to EQUAL a counter seems unreasonable.
