I am working with arduino one, the robot uses two motors, two encoder, one servo, one color sensor, one button, and one 8x2 lcd.
The sending of serial data to the lcd is made by pin 13, I want the animation to work in an infinite loop as long as the button is not pressed. With my code, the animation is performed, but it is not repeated, it is returned to the first line, which contains the "eyes closed" function,
In the first sketch,
I put the following code:
If (millis () - time1 >=1000){
But sync errors occurred
For this reason place the compound operators and aritmetic operator, this way:
If (millis () + time1 == 1000){
I would like the animation of the lcd to be made in infinite loop, if the button is not pressed
Code fragment:
unsigned long time1 = 0
unsigned long time2 = 0
unsigned long time3 = 0
void setup ()
//and the rest of the code...
while (b.isReleased()){
void eyesFunction ();
void eyesFunction (){
open_Eyes();
time1 = millis();
If (millis () + time2 == 1500){
closed_Eyes();
time2 = millis();
If (millis () + time3 == 2000){
happy _Eyes();
time3 = millis();
//etc....
sonicaction:
You've changed two things there. You've changed ">=" to "==" and "-" to "+".
You definitely want to stick with "-" there to calculate elapsed time.
There are other problems with the timing logic but I don't have time to address them right now.
Also, you can use >= instead of == if you're worried about perhaps missing an event. In this case however then you might need to store a flag so that you know that the task has been performed and don't keep repeating it.
// define state as byte
byte state = 0;
switch (state) {
case 0: open_Eyes();
if (millis() - time1 > 1000) {
time1 = millis();
state = 1;
case 1: close_Eyes();
if (millis () - time2 : 1500) {
time2 = millis();
state = 2;
case 2: happy_Eyes();
If (millis () - time3 > 2000) {
time3 = millis();
state = 0;
But there is a little problem. Your code calls eyesFunction during 1000 mseg doing nothing.
My suggestion starts with open_Eyes() during 1000 mseg and follows with the other two states.
The demo Several Things at a Time is an extended example of BWoD and illustrates the use of millis() to manage timing. It may help with understanding the technique.
