millis() function for multiple solenoids
Hello guys...i have a little problem. I have done some tings with arduino before so i am not totaly new (servos, lights, sensors...) but now i am using multiple solenoids for the first time... The thing is i have two solenoids that runindependently from each other (one has to be open for 1000ms and other for 500ms) i have tried millis() with LEDs and it is working (now i am waiting postal delivery-solenoids)...I have saperated power-24V for solenoids. Signals will go trough two relays....Now i am wondering if they will be waiting for this specific time (as LEDs) or they will be blinking?? thanks for answers
Code please
OK times are a little diferent but the idea is the same i think...
Stroj-p.ino (2.29 KB)
//Global Variables
const byte Senzor = A0; // pin za senzor
const byte Bat1 = 11; // pin od bata1
const byte Bat2 = 12;//pin od bata2
unsigned long SprozenSenzor_Millis;
unsigned long Bat2_millis;
unsigned long buttonInterval= 300;
unsigned long Bat1_OnAt;
unsigned long Bat2_OnAt;
unsigned long turnOn_Bat1_Delay = 500;
unsigned long turnOff_Bat1_Delay = 800 ;
unsigned long turnON_Bat2_Delay = 850;
unsigned long turnOff_Bat2_Delay = 700;
bool Bat1_Ready = false;
bool Bat2_Ready = false;
bool Bat1_State = false;
bool Bat2_State = false;
bool Senzor_State = false;
pinMode(Bat1, OUTPUT);
pinMode(Bat2, OUTPUT);
digitalWrite(Bat1, LOW);
digitalWrite(Bat2, LOW);
// --------BAT 1----------------------------------------
if (analogRead(Senzor)== LOW) {
SprozenSenzor_Millis = currentMillis;
Bat1_Ready = true;
if (Bat1_Ready) {
if ((unsigned long)(currentMillis - SprozenSenzor_Millis) >= turnOn_Bat1_Delay) {
digitalWrite(Bat1, HIGH);
Bat1_State = true;
Bat1_OnAt = currentMillis;
Bat1_Ready = false;
if (Bat1_State) {
if ((unsigned long)(currentMillis - Bat1_OnAt) >= turnOff_Bat1_Delay) {
Bat1_State = false;
//-------------------BAT 2------------------------
//Bat 2
if (analogRead(Senzor)==LOW) {
Bat1_Ready = true;
if (Bat1_Ready) {
if ((unsigned long)(currentMillis - SprozenSenzor_Millis) >= turnON_Bat2_Delay) {
digitalWrite(Bat2, HIGH);
Bat2_State = true;
Bat2_OnAt = currentMillis;
Bat2_Ready = false;
if (Bat2_State) {
if ((unsigned long)(currentMillis - Bat2_OnAt) >= turnOff_Bat2_Delay) {
Bat2_State = false;//
//debounce
unsigned long previousButtonMillis= millis();
if (millis() - previousButtonMillis >= buttonInterval) {
if (analogRead(Senzor) == LOW) {
Senzor_State = ! Senzor_State;
previousButtonMillis += buttonInterval;
If what you will be doing is to substitute solenoids for LEDs then they will behave in the same way. How are you powering the solenoids ?
This is an unusual way to test whether a pin is LOW. Why not use digitalRead() ?
How is the input pin wired ?
The demo Several Things at a Time illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
...R
Thanks for help, i appreciate.For power supply i will use 230/24VDC supplier from Schrack (somehow i have it at home) ..yes i taught it will be better if i use digitalRead instead of analogRead (i picked this on a internet and i was not sure) I will use your advice. For sensor i am using IR tracker from arduino...and i really should go trough this tutorial again. :wink:
How will the Arduino be turning the solenoids on and off ?
oh sorry i did not understand your question right. I will use two 5V relay module from Arduino.
