Hi there;
In my project, I measure the rotation torque with the hx711 and a torque sensor. I connected a 6V brushless DC motor to one side of the torque sensor, and on the other side is the material whose torque I want to measure. I have calibrated the torque sensor and I can get the correct measurement. I am sharing the code I wrote below with you.
#include "HX711.h"
#include <Wire.h>
#define startButton 3
#define motorSpeedPin 6
#define motorInputPin_1 7
#define motorInputPin_2 8
byte pinData = 4;
byte pinClk = 5;
HX711 scale;
float calibration_factor = 424956.0;
float torqueValue;
int startButtonState = 0;
int testCounter = 0;
bool startTest = false;
bool idleTest = false;
bool motorTest = false;
unsigned long waitTime;
unsigned long currentMillis;
LiquidCrystal_I2C lcd(0x27, 16, 2);
void TORQUE_SENSE();
void PAUSE();
void MOTOR();
void LCD_DISPLAY();
lcd.begin();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("SAYAC:");
lcd.setCursor(6, 0);
lcd.print(testCounter);
lcd.setCursor(0, 1);
lcd.print("TORK:");
lcd.setCursor(5, 1);
lcd.print(torqueValue);
pinMode(startButton, INPUT);
pinMode(motorInputPin_1, OUTPUT);
pinMode(motorInputPin_2, OUTPUT);
pinMode(motorSpeedPin, OUTPUT);
attachInterrupt(digitalPinToInterrupt(2), PAUSE, RISING);
scale.begin(pinData, pinClk);
scale.set_scale();
scale.tare();
long zero_factor = scale.read_average();
Serial.print("Zero factor: ");
Serial.println(zero_factor);
digitalWrite(motorSpeedPin, LOW);
digitalWrite(motorInputPin_1, LOW);
digitalWrite(motorInputPin_2, LOW);
currentMillis = millis();
startButtonState = digitalRead(startButton);
if (startButtonState == 1)
startTest = true;
if ((startButtonState == 0) && (idleTest == true))
torqueValue = 0;
lcd.clear();
lcd.print("TORK:");
idleTest = false;
while (startTest == true)
TORQUE_SENSE();
MOTOR();
LCD_DISPLAY();
void TORQUE_SENSE()
scale.set_scale(calibration_factor);
torqueValue = scale.get_units(10);
Serial.print("Reading: ");
Serial.print(torqueValue, 2);
Serial.print(" Nm");
lcd.print(torqueValue, 2);
delay(10);
void MOTOR()
bool motorIdle = false;
if (torqueValue < 0.3)
analogWrite(motorSpeedPin, 255);
digitalWrite(motorInputPin_1, HIGH);
waitTime = currentMillis;
motorTest = true;
else if ((motorTest == true) && (motorIdle == false))
analogWrite(motorSpeedPin, 150);
if (currentMillis - waitTime > 500)
motorIdle = true;
motorTest = false;
else if (motorIdle == true)
delay(3000);
digitalWrite(motorInputPin_2, HIGH);
delay(3000);
testCounter++;
motorTest = false;
motorIdle = false;
void LCD_DISPLAY()
void PAUSE()
startTest = false;
idleTest = true;
motorTest = false;
The part I want to ask you is that I measure time with millis in the code block below and when the time is completed, I want to exit that if statement.
motorIdle = true;
motorTest = false;
When I run the code, the motor turns with a 255 PWM signal and when the torque reaches the desired value, it continues to rotate with a 150PWM signal and hangs there. I used the millis function to get it out, normally after 500 milliseconds, I want the code to exit that statement.
I couldn't find which part of the code I made a mistake. Can you help me with this?
