The following is an example code from Arduino IDE. But in code for button bouce is delay.
Can you advise please how to put millis function instead.
Thanks in advance.
State change detection (edge detection)
Often, you don't need to know the state of a digital input all the time, but
you just need to know when the input changes from one state to another.
For example, you want to know when a button goes from OFF to ON. This is called
state change detection, or edge detection.
This example shows how to detect when a button or button changes from off to on
and on to off.
The circuit:
- pushbutton attached to pin 2 from +5V
- 10 kilohm resistor attached to pin 2 from ground
- LED attached from pin 13 to ground (or use the built-in LED on most
Arduino boards)
created 27 Sep 2005
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/ButtonStateChange
// this constant won't change:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button went from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
// if the current state is LOW then the button went from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state, for next time through the loop
lastButtonState = buttonState;
// turns on the LED every four button pushes by checking the modulo of the
// button push counter. the modulo function gives you the remainder of the
// division of two numbers:
if (buttonPushCounter % 4 == 0) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
Presumably if you don’t like that example, you have reported it to the site’s owners. Then I’m sure they’ll fix it like they fix all the other crap, like examples running servos from the 5V pin.
septillion:
So just have a look at the Bounce2 library
Talking of, here’s my state change detect template using Bounce2, changed for INPUT_PULLUP, and pruned of the counter stuff:
//StateChangeDetection example pruned of all the counting stuff and debounced
//active low
//debounced
#include <Bounce2.h>
Bounce debouncer = Bounce();
const int inputPin = 2; // the pin that the input voltage is attached to
int inputState; // current state of the input
int lastInputState=1; // previous state of the input
// initialize the input pin as a input pullup for active low
pinMode(inputPin, INPUT_PULLUP);
debouncer.attach(inputPin);
debouncer.interval(50);
Serial.println("Debounced state change detect, input pullup");
Serial.println("Press the button then release it");
debouncer.update();
// read the input pin:
inputState = debouncer.read();
// compare the inputState to its previous state (lastInputState)
if (inputState != lastInputState) //so it changed one way or the other
if (inputState == LOW) //pressed
// if the current state is LOW then the input
// went from not high to low:
Serial.print("Pressed");
// do the stuff that a PRESSED input triggers
else //released
// if the current state is HIGH then the input
// went from low to high: do nothing except print something if you want.
Serial.println("..released");
// do the stuff that a RELEASED input triggers
//for next time through the loop
lastInputState = inputState;
anthonyHope:
It’s a constant battle. But the least I can do is not shoot in my own foot and not feed newbies examples with serious bugs in it. Because it will come back to use.
But if it was up to me I would just disable the examples site until they are decent. But then again, I would also like if every second chapter in each Arduino tutorial was called “And now NEVER EVER use delay() agian”.
And Bounce2 can also take care of the state change detection
const byte buttonPin = 2; // the pin that the input voltage is attached to
Bounce button = Bounce(); //(de)Bounce object representing the button
unsigned int buttonPushCounter = 0; // counter for the number of button presses
button.attach(buttonPin, INPUT_PULLUP);
button.interval(50);
button.update();
//Bounce2 also takes care of the state change detection
if (button.fell()) //became pressed
Serial.print("Pressed, ");
else if(button.rose()) //became released
Serial.println("...released");
Well I didn't know about those, so thanks for that.
Are they new-ish features? I don't recall seeing them when I made my template, the file of which was created over 2.5 years ago, but that's not to say they weren't there.
if (buttonState != lastButtonState) { // if the state has changed, increment the counter
delay(50);
changes to:
unsigned long currentTime = millis();
static unsigned long previousStateChangeTime;
const unsigned long debounceInterval = 50;
if (buttonState != lastButtonState && currentTime - previousStateChangeTime >= debounceInterval)
previousStateChangeTime = currentTime;
