Hello, i am trying to build an automated greenhouse but have become stumped by responsiveness.
Currently my code cycles through Temperature, Humidity, Moisture, and Light values on an LCD display and the values of the sensors DHT11, LDR and a soil moisture Probe.
This works as intended however the delay(2000); after each LCD print out slows down the program and only when the program cycles around do the sensors trigger the corresponding outputs.
My question is how can i substitute Millis(); for delay as i believe this is what i need to do?
p.s i have been trying to sort this for the last 3 days.
My code is attached any help would be greatly appreciated.
#include <dht.h> // include the dht.h sensor libaries
#include <LiquidCrystal.h> //inculde LCD library
dht DHT;
#define DHT11_PIN 7 // define sensor input pin to pin 7
int Tempthreshold = 24; // set threshold i.e if above or below
int Humidthreshold = 50; // set threshold i.e if above or below
int Soilthreshold = 50; // set moisture content threshold
int lightthreshold = 400; // set threshold for LDR i.e if above or below
int LDRsensorPin = A0; // set pin for LDR
int SoilsensorPin = A1; // assign A1 for soil sensor
int ledPin = 8; // select the pin for the LED
int ledPin1 = 9; //
int fanPin = 13; // connect this pin for the LED
int val;
int Mapped;
int LDRvalue;
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin, OUTPUT); // set LED pin and an output
pinMode(fanPin, OUTPUT); // set fanPin 13 as an output
Serial.begin(9600); // begin serial read out
lcd.begin(16, 2); // set up the LCD's number of columns and rows:
lcd.clear(); // clear LCD
lcd.setCursor (0, 0); // set position for next line
lcd.print("WELCOME TO"); // Print to the LCD.
lcd.setCursor (0, 1); // set position for next line
lcd.print("GREENDUINO"); // Print to the LCD.
delay(5000); // wait
lcd.clear(); // clear lcd
// ^^^ Welcoming message ^^^
int LDRvalue = analogRead(LDRsensorPin);
int val = analogRead(A1);
Mapped = map (val, 200 , 700, 100, 0); // map soilmoisture between 0 - 100 instead of 0 - 1023
int chk = DHT.read11(DHT11_PIN); // check sensor
if (DHT.temperature > Tempthreshold) { // if the analog value is high enough, turn on the LED:
digitalWrite(fanPin, HIGH); // turn LED on
digitalWrite(fanPin, LOW); // turn LED off
if (DHT.humidity > Humidthreshold) { // if the analog value is high enough, turn on the LED:
if (LDRvalue < lightthreshold) {
digitalWrite(ledPin, LOW); // turn LED off
digitalWrite(ledPin, HIGH); // turn LED on
if (Mapped > Soilthreshold) {
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin1, LOW);
Serial.print("Temperature = "); // print "temprature" in serial monitor
Serial.println(DHT.temperature, 0); // print value of sensor
lcd.clear(); // clears lcd
lcd.setCursor (0, 0); // set position on lcd
lcd.print("Temp = "); // print "temprature" on lcd
lcd.print(DHT.temperature, 0); // print temprature value to lcd
lcd.print((char)223); //print symbol to lcd
lcd.print("C"); // print "C" to lcd
delay(2000);
Serial.print("Humidity = "); // print "Humidity" in serial monitor
Serial.println(DHT.humidity, 0); // print value of sensor
lcd.clear();
lcd.print("Humidity = "); // print "Humidity" on lcd
lcd.print(DHT.humidity, 0); // print humidity value lcd
lcd.print ("%"); // print "%" to lcd
delay(2000);
Serial.print("SoilMoistureContent =");
Serial.println(Mapped);
lcd.print("Moisture = "); // print Moisture
lcd.print(Mapped); // display soil moisture content value
lcd.print("%");
delay(2000);
Serial.print("LDR = ");
Serial.println(LDRvalue);
lcd.print("LDR = "); // print Moisture
lcd.print(LDRvalue); // display soil moisture content value
lcd.print("%");
delay(2000);
GREENHOUSE.ino (3.67 KB)
