I tried but still the size is bit big for ATtiny MC. I am going to use only for few pins why should we go for big MC?
I need the requirement like this...
case OFF:
if (pin1State == HIGH) {
digitalWrite(RELAY_PIN, OFF);
if (pin2State == LOW) {
delay(10000); --> instead of delay I need timer logic
It is important you tell us that you only had 2k of memory for the sketch.
Not doing so steels our time.
In the future, please, give us all pertinent information so volunteers can best gauge if they should even try to contribute to a thread. -
Please follow the posting guidelines so we can best help you with answers.
sorry that's my mistake. I will use Arduino nano for testing purpose.
- The sketch from Post #9 should work on a NANO; it is based on the preamble in Post #8.
- You can remove the Serial code, but I don’t think it will be enough for 2k memory.
Serial.begin(115200); <——-<<<<< remove
- Okay, I removed floating point math and Serial, the size is now down to only
1436 Bytes
Try this version
// https://forum.arduino.cc/t/millis-logic-not-working-properly/1363091
// Millis Problem
// Version YY/MM/DD Comments
// 1.00 25/03/12 Running code
// Notes:
// I have the following sketch.
// At power up time, the relay is opended
// If pin2 is closed, pin1 is open, and relay is opened, then the relay should close.
// While relay is closed, if pin2 opens, the relay should go OFF
// and then the device should be in suspended state for 20 seconds.
// Within this 20 seconds all input pins should not work but other output pins should work as usual like blink led.
#include <digitalWriteFast.h>
#define LEDon HIGH //PIN---[220R]---A[LED]K---GND
#define LEDoff LOW
#define PRESSED LOW //+5V---[Internal 50k]---PIN---[Switch]---GND
#define RELEASED HIGH
#define OPENED HIGH //+5V---[Internal 50k]---PIN---[Switch]---GND
#define CLOSED LOW
#define ENABLED true
#define DISABLED false
#define RELAYopened HIGH
#define RELAYclosed LOW
// millis() / micros() B a s e d T I M E R S
makeTIMER toggleLED =
//.TimerType, .Interval, .TimerFlag, .Restart
MILLIS/MICROS, 500ul, ENABLED/DISABLED, YES/NO
TIMER functions we can access:
toggleLED.checkTIMER();
toggleLED.enableRestartTIMER();
toggleLED.restartTIMER()
toggleLED.disableTIMER();
toggleLED.expireTimer();
toggleLED.setInterval(100ul);
//These TIMER objects are non-blocking
class makeTIMER
#define MILLIS 0
#define MICROS 1
#define YES true
#define NO false
#define STILLtiming 0
#define EXPIRED 1
#define TIMERdisabled 2
private:
public:
unsigned long Time; //when the TIMER started
//these "members" are needed to define a TIMER
byte TimerType; //what kind of TIMER is this? MILLIS/MICROS
unsigned long Interval; //delay time which we are looking for
bool TimerFlag; //is the TIMER enabled ? ENABLED/DISABLED
bool Restart; //do we restart this TIMER ? YES/NO
//constructor with no parameters
makeTIMER()
TimerType = MILLIS;
Interval = 1000ul;
TimerFlag = ENABLED;
Restart = YES;
Time = 0;
//constructor with parameters
makeTIMER(byte _TimerType, unsigned long _Interval,
bool _TimerFlag, bool _Restart)
TimerType = _TimerType;
Interval = _Interval;
TimerFlag = _TimerFlag;
Restart = _Restart;
Time = 0;
//condition returned: STILLtiming (0), EXPIRED (1) or TIMERdisabled (2)
//function to check the state of our TIMER ex: if(myTimer.checkTIMER() == EXPIRED);
byte checkTIMER()
//is this TIMER enabled ?
if (TimerFlag == ENABLED)
//has it expired ?
if (getTime() - Time >= Interval)
//should this TIMER restart again?
if (Restart == YES)
//restart this TIMER
Time = getTime();
//this TIMER has expired
return EXPIRED;
return STILLtiming;
} //END of if (TimerFlag == ENABLED)
//this TIMER is disabled
return TIMERdisabled;
} //END of checkTime()
//function to enable and restart this TIMER ex: myTimer.enableRestartTIMER();
void enableRestartTIMER()
Time = getTime();
} //END of enableRestartTIMER()
//function to disable this TIMER ex: myTimer.disableTIMER();
void disableTIMER()
TimerFlag = DISABLED;
} //END of disableTIMER()
//function to restart this TIMER ex: myTimer.restartTIMER();
void restartTIMER()
Time = getTime();
} //END of restartTIMER()
//function to force this TIMER to expire ex: myTimer.expireTimer();
void expireTimer()
//force this TIMER to expire
Time = getTime() - Interval;
} //END of expireTimer()
//function to set the Interval for this TIMER ex: myTimer.setInterval(100);
void setInterval(unsigned long value)
//set the Interval
Interval = value;
} //END of setInterval()
//function to return the current time
unsigned long getTime()
//return the time i.e. millis() or micros()
if (TimerType == MILLIS)
return millis();
return micros();
} //END of getTime()
}; //END of class makeTIMER
// D e f i n e a l l o u r T I M E R S
/*example
//example: uses default library values
//makeTIMER testTIMER{};
makeTIMER heartbeatTIMER =
//.TimerType, .Interval, .TimerFlag, .Restart, .SpeedAdjustPin
MILLIS, 500ul, ENABLED, YES
makeTIMER switchesTIMER =
MILLIS, 5ul, ENABLED, YES
makeTIMER relayDelayTIMER =
MILLIS, 1000ul, DISABLED, NO
// c l a s s m a k e I n p u t
//a class to define input objects, switches or sensors
#define NOTvalidated 0
#define VALIDATED 1
#define NOchange 2
class makeInput
private:
public:
static byte filter;
//say the above validating "filter" variable is set to 10
//if we scan "inputs" every 5ms
//i.e. we sample our inputs every 5ms looking for a change in state.
//5ms * 10 = 50ms is needed to validate a switch change in state.
//i.e. A switch change in state is valid "only after" 10 identical changes are detected.
//This technique is used to filter out EMI (spikes), noise, etc.
//i.e. we ignore switch changes in state that are less than 50ms.
byte pin; //the digital input pin number
byte lastState; //the state the input was last in
unsigned long switchTime; //the time the switch was closed
byte counter; //a counter used to validate a switch change in state
makeInput(byte _pin, byte _lastState)
pin = _pin;
lastState = _lastState;
switchTime = 0;
counter = 0;
pinMode(pin, INPUT_PULLUP);
//condition returned: NOTvalidated (0), VALIDATED (1) or NOchange (2)
//check to see if the input object has had a valid state change
byte validChange()
byte pinState = digitalRead(pin);
//has there been an input change in state ?
if (lastState != pinState)
counter++;
//is this "change in state" stable ?
if (counter >= filter)
//an input change has been validated
//get ready for the next sequence
counter = 0;
//update to this new state
lastState = pinState;
return VALIDATED;
return NOTvalidated;
//there has not been an input change in state
counter = 0;
return NOchange;
} //END of validChange()
}; //END of class makeInput
//initialize the validating filter
byte makeInput::filter = 10;
// G P I O s A n d V a r i a b l e s
//INPUTS
//============ GPIO 2
makeInput switch1 =
//.pin, .lastState
2, OPENED
//============ GPIO 3
makeInput switch2 =
//.pin, .lastState
3, OPENED
//OUTPUTS
const byte relayPin = 4;
const byte heartbeatLED = 5;
//VARIABLES
//unsigned long suspenedInterval = 10 * 1000ul; //10 seconds
unsigned long suspenedInterval = 20 * 1000ul; //20 seconds
// s e t u p ( )
digitalWriteFast(heartbeatLED, LEDoff);
pinMode(heartbeatLED, OUTPUT);
//at power up time, the relay is opended
digitalWriteFast(relayPin, RELAYopened);
pinMode(relayPin, OUTPUT);
} //END of setup()
// l o o p ( )
//Print the time it takes to return to this same spot.
//comment the next 3 lines when no longer needed
//static unsigned long startTime;
//Serial.println(micros() - startTime);
//startTime = micros();
//======================================================================== T I M E R heartbeatLED
//condition returned: STILLtiming, EXPIRED or TIMERdisabled
//is it time to toggle the heartbeat LED ?
if (heartbeatTIMER.checkTIMER() == EXPIRED)
//toggle the heartbeat LED
digitalWriteFast(heartbeatLED, digitalRead(heartbeatLED) == HIGH ? LOW : HIGH);
//======================================================================== T I M E R switches
//is it time to check our switches ?
if (switchesTIMER.checkTIMER() == EXPIRED)
checkSwitches();
//======================================================================== T I M E R relayDelay
//has this TIMER expired ?
if (relayDelayTIMER.checkTIMER() == EXPIRED)
//we are finished with this TIMER
relayDelayTIMER.disableTIMER();
// Other non blocking code goes here
} //END of loop()
// c h e c k S w i t c h e s ( )
//object.validChange() - checks to see if there was a valid state change
//object.pin - hardware pin number
//object.lastState - the state the switch is in right now
//object.switchTime - an unsigned long variable where we can save millis()
void checkSwitches()
//======================================================================== switch1
//was there a validated input change ?
if (switch1.validChange() == VALIDATED)
//did this switch go closed ?
if (switch1.lastState == CLOSED)
//this switch went opened
} //END of mySwitch1
//======================================================================== switch2
if (switch2.validChange() == VALIDATED)
if (switch2.lastState == CLOSED)
//make sure we are not timing
if (relayDelayTIMER.checkTIMER() == TIMERdisabled)
if (digitalRead(relayPin) == RELAYopened)
if (switch1.lastState == OPENED)
digitalWriteFast(relayPin, RELAYclosed);
if (digitalRead(relayPin) == RELAYclosed)
//set TIMER interval
relayDelayTIMER.setInterval(suspenedInterval);
//Start timing
relayDelayTIMER.enableRestartTIMER();
} //END of switch2
} //END of checkSwitches()
EDIT, updated sketch
REMOVED 10 more bytes.
Nano pin 1 is used for Serial.
I did have questions in post #16 but the parallel tasks method I showed (which has no Serial, ATtiny serial is different anyway) takes little room.
The ATtiny's I have are 84's with 8K flash and 8 pins. ![]()
I mean ATtiny2313 MC.
Code uploaded and I observed the following
- When I connected pin3 to GND, the relay was triggered.
- After removing pin3 from GND, if I reconnect pin3 to GND within 20 seconds, the input on pin3 doesn't respond. However, if I wait for more than 20 seconds and then connect pin3 to GND, the relay is triggered as expected.
- When I connect pin3 with GND, Relay triggered then I removed pin3 from GND and within 20 seconds the PIN3 is connected to GND. I observed that the relay is not triggered even after 20 seconds passed though the pin3 is already connected with GND. Ideally it should on as timer reset.
- Please confirm this preamble.
// Notes:
// - At power up time, the relay is opended
// - If GPIO 3 is closed, GPIO 2 is open, and relay is opened: the relay should close.
// - While relay is closed, if pin2 opens, the relay should go OFF and
// then the device should be in suspended state for 20 seconds.
// - When the relay is suspended and the GPIO 3 is closed and kept closed (GPIO 2 still open),
// the relay closes again. <-----<<<<< N E W parameter
small correction
// Notes:
// - While relay is closed, if pin3 opens, the relay should go OFF and
I see that. I meant ATtiny85 which is physically smaller (8 pins) but has 8K flash and 256 bytes RAM. 3 of those can fit in a 24 pin socket!
I wanted to know about pin 1 and if pin 1 or pin 2 are connected to a button or other kind of contact switch like a microswitch?
Once millis timing is used and there is no blocking code.. there is no need to keep the status blink or button code in the -pin 1-pin 2-relay code- at all, the final hex can be very small.
But I wonder about the role of pin 1 and did leave 4 possible states for that ... if you would like to go that route.
Otherwise I will stop tracking this thread.
see post#34
The code I gave in Reply #18 is 1202 bytes (compiled for a Nano, I don't have the AtTiny chips downloaded)
Update: Using the digitalWriteFast library reduced it down to 1060 bytes
New parameter incorporated.
Try the version:
// Millis Problem
// Notes:
// - If GPIO 3 (switch2) is closed, GPIO 2 (switch1) is open, and relay is opened: the relay should close.
// - While relay is closed, if GPIO 3 (switch2) opens, the relay should open and
// - When the relay is no longer suspended and the GPIO 3 (switch2) is closed and
// kept closed (GPIO 2 (switch1) still open), the relay closes again.
#define LEDoff LOW
#define CLOSED LOW
class makeTIMER
#define MILLIS 0
#define MICROS 1
#define YES true
#define NO false
#define EXPIRED 1
private:
public:
Restart = _Restart;
Time = 0;
byte checkTIMER()
//has it expired ?
if (Restart == YES)
Time = getTime();
return EXPIRED;
return STILLtiming;
Time = getTime();
void disableTIMER()
void restartTIMER()
Time = getTime();
void expireTimer()
//set the Interval
Interval = value;
return millis();
return micros();
/*example
#define VALIDATED 1
#define NOchange 2
class makeInput
private:
public:
static byte filter;
pin = _pin;
switchTime = 0;
counter = 0;
byte validChange()
counter++;
counter = 0;
return VALIDATED;
counter = 0;
return NOchange;
//INPUTS
makeInput switch1 =
//.pin, .lastState
2, OPENED
makeInput switch2 =
//.pin, .lastState
3, OPENED
//OUTPUTS
//VARIABLES
// s e t u p ( )
} //END of setup()
// l o o p ( )
checkSwitches();
//is switch2 now closed and switch1 is still open ?
if (switch2.lastState == CLOSED && switch1.lastState == OPENED)
} //END of loop()
//nothing to do here
//Start timing
} //END of switch2
Your whole code looks good and to the point.
But what if PIN1 is on a bouncy-switch? Or did I miss that detail somewhere?
By default at startup all AVR pins are INPUT LOW.
Yes it is working as expected ![]()
You are correct, I am not debouncing the switches. That could be added, it could also be done with hardware. I merely went off the info I was given and nothing more.
Good
Go through the sketch and examine what the code looks like.
If you want to learn this stuff, ask questions on the how and why things are done.
Before starting to code your projects, always start with a schematic and an accurate preamble.
