system
1
I am trying to build a simple on delay timer. I would like to press and hold a pushbutton for 5 seconds and then a LED would come on.
int ledPin = 13;
int buttonPin = 2;
int ledState = LOW;
int state=0;
long previousMillis = 0;
long interval = 5000;
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
state=digitalRead(buttonPin);
if (state==HIGH)
if(currentMillis - previousMillis > interval )
if (ledState == LOW)
ledState = HIGH;}
else{
ledState= LOW;
digitalWrite(ledPin, ledState);
N2scouting:
And? (hint: anything wrong?)
system
4
I fixed the indenting to make the code a little clearer...
if (state==HIGH)
ledState = HIGH;
ledState= LOW;
The only time you call digitalwrite on the led is when it's low. You then set it low...
You did most of the OP's work
OP, please re-do your logic now that nickvd has properly indented your code. Just give it a try.
