Die ersten 2 Wasserpumpen sollen im Stundentackt für 1 Minute lang Strom bekommen.
Die dritte Wasserpumpe läuft alle 3 Sekunden für nur wenige Millisekunden lang.
Jedoch starten die 2 Wasserpumpen erst gar nicht.
Wenn ich jedoch den Takt von 1 Stunde auf bsw. 10 Minuten reduziere klappt es.
Hat jemand einen Tipp woran das liegen kann?
#include <Wire.h>
#include <Adafruit_MotorShield.h>
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
Adafruit_DCMotor *myMotor2 = AFMS.getMotor(2);
Adafruit_DCMotor *myMotor3 = AFMS.getMotor(3);
class Flasher
// Class Member Variables
// These are initialized at startup
long MotorOnTime; // milliseconds of on-time
long MotorOffTime; // milliseconds of off-time
int MotorSpeed; // milliseconds of off-time
Adafruit_DCMotor *motor;
// These maintain the current state
int MotorState; // MotorState used to set the Motor
unsigned long previousMillis; // will store last time Motor was updated
// Constructor - creates a Flasher
// and initializes the member variables and state
public:
Flasher(Adafruit_DCMotor *p_motor)
MotorState = 0;
previousMillis = 0;
// Set the speed to start, from 0 (off) to 255 (max speed)
motor = p_motor;
void Update(long on, long off, int m_speed)
MotorOnTime = on;
MotorOffTime = off;
MotorSpeed = m_speed;
motor->setSpeed(MotorSpeed);
// check to see if it's time to change the state of the LED
if((MotorState == 1) && (currentMillis - previousMillis >= MotorOnTime))
MotorState = 0; // Turn it off
previousMillis = currentMillis; // Remember the time
Serial.println(MotorOnTime);
motor->run(FORWARD);
else if ((MotorState == 0) && (currentMillis - previousMillis >= MotorOffTime))
MotorState = 1; // turn it on
Serial.println(MotorOffTime);
motor->run(RELEASE);
Flasher pumpe1(myMotor);
Flasher pumpe2(myMotor2);
Flasher pumpe3(myMotor3);
Serial.println("Adafruit Motorshield v2 - DC Motor test!");
AFMS.begin(); // create with the default frequency 1.6KHz
//AFMS.begin(1000); // OR with a different frequency, say 1KHz
pumpe1.Update(3600000UL,60000,255);
pumpe2.Update(3600000UL,60000,255);
pumpe3.Update(3000,200,50);
mich springt nichts an (außer die permanenten Parameterübergaben, die es wohl kaum braucht, aber auch nicht die Ursache sein werden).
Wie kannst du sicher sein, dass dein Sketch überhaupt die Stunde durchläuft und nicht schon vorher z.B. wegen einer kurzen Stromschwankung einen Reset durchführt?
Daher nur mal so auf Verdacht:
Serial.print Ausgaben ergänzen
auf einem Display die aktuellen Millis und previous Millis ausgeben lassen.
Erwartest Du Negativ-Laufzeiten?
Wenn nicht, änder das LONG in UNSIGNED LONG für die Zeiten.
LONG (auf Uno/Nano) = 31 Bit, max 2147483647 Du möchtest darin aber 3600000000 speichern - passt nicht. Denke, der Kompiler müsste Dir dazu eine Warnung auswerfen - in den Einstellungen dafür die ausführlichen Warnungen beim Kompilieren und Hochladen anklicken. Erst bei UNSIGNED hast Du die 32 Bit, was den Wertebereich nach oben verdoppelt - Da passen dann auch die 3,6 Mrd rein.
... hatte Da 3 Nullen zu viel 'gezählt' - mit nur 3,6 Mio sollte auch LONG passen
MfG
naja aber nur dann, wenn die Bedingung erfüllt ist.
Du suchst ja jetzt einen Grund, warum du da nicht reinkommst, also solltest die Ausgaben so machen, dass sich die laufend aktualsieren so dass du es auch siehst oder?
Habe da mal ein bisschen drüber gefegt...
Versucht, möglichst viel unverändert zu übernehmen.
Also: Da lässt sich noch einiges verbessern.
#include <Wire.h>
#include <CombieTypeMangling.h>
using namespace Combie::Millis;
class Flasher
private:
unsigned long MotorOnTime; // milliseconds of on-time
unsigned long MotorOffTime; // milliseconds of off-time
unsigned int MotorSpeed;
enum MotorState {EIN,LAUFZEIT,AUS,WARTEZEIT};
MotorState motorState; // MotorState used to set the Motor
unsigned long timestamp; // will store last time Motor was updated
public:
Flasher(Adafruit_DCMotor *p_motor):motorState(EIN),motor(p_motor),timestamp(0){}
void set(const unsigned long on, const unsigned long off, const unsigned int m_speed)
MotorOnTime = on;
MotorOffTime = off;
void run()
switch(motorState)
case EIN: timestamp = currentMillis; // Remember the time
motorState = LAUFZEIT;
case LAUFZEIT: if(currentMillis - timestamp >= MotorOnTime)
motorState = AUS;
case AUS: timestamp = currentMillis; // Remember the time
motorState = WARTEZEIT;
case WARTEZEIT: if(currentMillis - timestamp >= MotorOffTime)
motorState = EIN;
pumpe1.set( 1_hr, 1_min, 255);
pumpe2.set( 1_hr, 1_min, 255);
pumpe3.set( 3_sec, 200_ms, 50);
// testdaten
pumpe1.set(2_sec, 1.5_sec, 255);
pumpe2.set(3_sec, 4_sec, 255);
pumpe3.set(5_sec, 2.22_sec, 50);
pumpe1.run();
pumpe2.run();
pumpe3.run();
