Miliis function is not working properly when internal 1 MHz oscillator is used in the ATTiny85
I programmed ATTINY85 to change an LED state every 10 Seconds... It starts well... But after 3 minutes or so, i can see a 5 second advancement in the process. ie.,LED changes state 5 seconds before itself... When i used 8 Mhz mode it was some 3 seconds and when i used 20 MHz mode with external oscillator i can see a delay of 2 seconds after 5 Minutes...
Finally i used a 16 MHz crystal and it was working fine...
Now what should i do to make it work perfectly at 1MHz mode?
i tried changing some values in boards.txt... everything seems to be fine in it... So didnt change anything....
The internal oscillator is jittery and not very accurate. I was playing with one in a 328p and it was about 5% off. By tweaking the OSCCAL register I could get it to about .5%. The stock value was 65 and I think 61 was the best in the end. It might have been 60, I didn't write it down. At any rate, OSCCAL will allow you to tweak the internal oscillator, check out the datasheet. A little goes a long way, don't expect to have to change it much.
Use a crystal for the best accuracy. There is a clock prescale register that can divide the system clock down. You can set it to divide the 16MHz crystal by 16 to get 1MHz. Check the datasheet for the CLKPR register and CLKPS bits.
Watchdog works with the oscillator, so if one is off, so will the other. External crystal with load caps is the way to do. You can get surface mount pieces that are extremely small.
The datasheet says the internal oscillator calibration from the factory is only accurate to ±10%, so "perfect" is a bit of an unrealistic expectation here. Actually, it's always an unrealistic expectation with real-world devices. Sounds like your particular device is within 3% (5/180), so pretty good really. As others have noted, there is the option of further calibration, again the datasheet says that ±1% should be achievable. If that still doesn't meet requirements, then another clock source should be considered.
This is what happens when you're working with some 30+ 6th graders in one class room (one period) trying to build solar cars. What I meant to say was that it works independent of the oscillator however the chances of it too not being as accurate as the OP wants it to be is very likely ...
But then, the OP also doesn't indicate what the timing is being used for. Perhaps it's not something that needs atomic clock accuracy ... or something where an RTC is a better solution.
KirAsh4:
This is what happens when you’re working with some 30+ 6th graders in one class room (one period) trying to build solar cars. What I meant to say was that it works independent of the oscillator however the chances of it too not being as accurate as the OP wants it to be is very likely …
Heck, we knew what ya meant Got those kids programming Arduinos yet?
