#include<Wire.h> //Include kutuphane ı2 data Wire
#define MCP4725 0X60
unsigned long adc;
unsigned long buffer[3];
unsigned int rdtx=0;
unsigned int rdtmax=20;
unsigned long karsilastir=0;
unsigned int karsmax=260;
unsigned long zaman1=0,zaman2=0,zaman3=0,zaman4=0,zaman5=0;
byte trp=2; // tr out:
byte trn=3; // tr cıkış :
byte kazancled=4; // led output:
byte npoutled=5; // led cıkısı:
byte pwrled=6; // led cıkış :
byte incompy = 7; // buton opamp 1-0 gırış:
byte outcompv=8; // ao-a1 karsılastırma cıkış :
byte incompx = 9; // 8 out koprusu 1-0 gırış:
byte setswic=10; // led cıkısı:
pinMode ( trp, OUTPUT ); // s :
pinMode ( trn , OUTPUT ); // s :
pinMode ( kazancled, OUTPUT ); // s :
pinMode (npoutled,OUTPUT); // sinyal cıkış NPN ve PNP out :
pinMode (pwrled,OUTPUT); // power ve rdt flaşör :
pinMode(incompy, INPUT); // modlar :
pinMode ( outcompv , OUTPUT ); // s :
pinMode(incompx, INPUT); // modlar :
pinMode ( setswic, OUTPUT ); // s :
Wire.begin(0x60);
Wire.setClock (400000);
{ if ( millis () - zaman1 >= 100)
karsilastir = analogRead(A6);
if (karsilastir <= karsmax )
{digitalWrite(setswic, !digitalRead(setswic)); }
zaman1 = millis ();
{ if (millis () -zaman2 >=100)
adc = analogRead(A7);
adc = map(adc, 0 ,1023 ,0,4095 ) ;
buffer[0] = 0b01000000;
buffer[1] = adc >> 4;
buffer[2] = adc << 4;
Wire.beginTransmission (0x60);
Wire.write(buffer[0]);
Wire.write(buffer[1]);
Wire.write(buffer[2]);
Wire.endTransmission();
zaman2=millis();
rdtx = analogRead(A2);
if (rdtx <= rdtmax )
{ if (millis()-zaman3 >= 100)
{digitalWrite(pwrled, !digitalRead( pwrled)); }
zaman3=millis();
unsigned long compr1 ,compr2 ;
compr1 = analogRead ( A0) ;
compr2 = analogRead ( A1) ;
if (compr1 <= compr2 )
{ if (millis()-zaman4 >= 100)
{digitalWrite(outcompv, !digitalRead(outcompv )); }
zaman4=millis();
bool incompx = digitalRead(7);
bool incompy = digitalRead(9);
if (incompx == 1 && incompy == 1)
{ if (millis()-zaman5 >= 100)
{digitalWrite(trp, !digitalRead(trp )); }
{digitalWrite(trn, !digitalRead(trn )); }
{digitalWrite(npoutled, !digitalRead( npoutled )); }
zaman5=millis();
type or paste code here
millis() not working where did i make the error
is compiling
It doesn't work when I install it on the system
Have you printed the value returned to see if it changes? I can assure you it is working.
Paul
I have a mistake, can you review the codes?
do you mean values
here
sample kode here
Explain what you expected to happen, and what happened instead.
Did I mistype my millis codes?
{ } are the pretty parentheses wrong?
or
Are the positions of the codes written wrong?
I uploaded after compiling the codes
not working
See reply #5.
You do seems to have a few { } pairs that do not really serve any purpose (not connected to any type of conditional statement).
There are also a few places where you check if millis() - zamanX >= 100 then set the value of zamanX regardless of the outcome of the if statement.
Your timers are nested very deeply. Did you intend for each timer to only check when all the previous timers were done?
zaman1 = millis ();
if (millis () - zaman2 >= 100)
adc = map(adc, 0 , 1023 , 0, 4095 ) ;
zaman2 = millis();
if (millis() - zaman3 >= 100)
zaman3 = millis();
unsigned long compr1 , compr2 ;
if (millis() - zaman4 >= 100)
zaman4 = millis();
if (millis() - zaman5 >= 100)
zaman5 = millis();
It would be more common to have each timer separate:
zaman1 = millis ();
zaman2 = millis();
zaman3 = millis();
zaman4 = millis();
zaman5 = millis();
I compiled the codes and expected it to work normally.
I didn't want to use delay in all sections just to control with militia
I didn't have a purpose
{ } curly braces
I didn't think it would go this deep
thank you so much john wasser
how can i adapt this code
the code is here
the code is here
MCP.writeDAC(819*5)
code here
55 / 5000
Çeviri sonuçları
original codes are delayed and working here`
unsigned long adc;
Wire.begin(0x60);
karsilastir = analogRead(A6); if (karsilastir <= karsmax )
{digitalWrite(setswic, 1); delay (20);}
{digitalWrite(setswic, 0); delay (22); }
{delay (20);}
{digitalWrite(pwrled, 1); delay (20);}
{digitalWrite(pwrled, 0); delay (50);}
{digitalWrite(pwrled, 1); delay (60);}
{digitalWrite (outcompv ,1); delay(10);}
{digitalWrite (outcompv ,0); delay (10);}
{digitalWrite(trp, 1);
digitalWrite(trn, 1);
digitalWrite(npoutled, 1); delay (150); }
{digitalWrite(trp, 0);
digitalWrite(trn, 0);
digitalWrite(npoutled, 0); delay (40); }
I want to do all the delays with millis
Code compiled with millis works unstable here
There are flashing LEDs can you help me johnwasser
unsigned long adc;
Wire.begin(0x60);
zaman1 = millis ();
zaman2 = millis();
zaman3 = millis();
zaman4 = millis();
zaman5 = millis();
